When my system running Ubuntu 14.04 is under a heavy load (for instance a long video encode) nautilus fails to start. I've seen this similar question: Nautilus occasionally stops working
But although the error when launched in terminal is identical, Could not register the application: Timeout was reached it doesn't appear to apply in this case.
I tried all the answers in the aforementioned similar question.
Results are as follows
me@zippy-64bit:~$ killall nautilus
me@zippy-64bit:~$ nautilus -q
I ran a nautilus self-check with the following results:
me@zippy-64bit:~$ nautilus -c
running nautilus_self_check_file_utilities
running nautilus_self_check_file_operations
running nautilus_self_check_directory
running nautilus_self_check_canvas_container
gvfs-mount shows no remote mounts as seen below.
me@zippy-64bit:~$ gvfs-mount -l
Drive(0): TOSHIBA THNSNH128GBST
  Type: GProxyDrive (GProxyVolumeMonitorUDisks2)
  Volume(0): 13 GB Volume
    Type: GProxyVolume (GProxyVolumeMonitorUDisks2)
Drive(1): WDC WD2003FZEX-00Z4SA0
Drive(2): WDC WD3001FAEX-00MJRA0
Drive(3): Optiarc DVD RW AD-7280S
me@zippy-64bit:~$ man nautilus
gksu nautilus launches instantly perhaps due to a super user task being launched at higher priority.
I'd like to determine if extending the timeout under these conditions would allow nautilus to open. Is there a way I can accomplish this or any other effective workaround? Ideally I'd like to accomplish this without interrupting the encoding job currently running.
Elder Geek
  • 36,752
This problem was resolved by installing nemo as suggested by @Fabby in a comment here.
I installed with:
sudo apt-get install nemo
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
  libnemo-extension1 nemo-data nemo-fileroller
The following NEW packages will be installed:
  libnemo-extension1 nemo nemo-data nemo-fileroller
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/1,075 kB of archives.
After this operation, 6,116 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Further research indicates that I was affected by this bug. IF you are also affected please subscribe to the bug so that the developers can get a sense of it's impact and budget their time accordingly.
Elder Geek
  • 36,752
