15
On ubuntu 14.04 LTS, sometimes my computer fails to launch Nautilus. This always happens when I have been working on it for a while (maybe after suspending and waking it again?), never when I just turned it on. I suspect this is related to gvfs filesystems mounted regularly and then left alone for a while. nautilus -q and similar commands give
Could not register the application: Timeout was reached
whereas sudo nautilus does launch it.
This sounds related, but I don't understand the solution.
Logging out and back in solves the problem.
I know that other people have had the same problem in the past. I do think this is a serious issue. I reinstalled ubuntu recently (for other reasons) and the problem is still there. Might be worth mentioning that I have nautilus-dropbox installed.
Martino
  • 200
5 Answers5
14
I had the same problem this morning! For no apparent reason.
I manage to restart nautilus by
killall nautilus
nautilus -q
nautilus
I'm trying to figure out what caused the mysterious failure.
Andrea Borga
  • 1,100
Yes, it is problably gvfs related.
The problem is this bug: gvfs should unmount remote mounts on network disconnect
Running this should allow you to use nautilus again.
gvfs-mount -s sftp & gvfs-mount -s smb & gvfs-mount -s ftp
Can take a few seconds to work
You can run it automatically. You have to write a script and save it as:
/etc/pm/sleep.d/20-gvfs
#!/bin/bash
case "$1" in
suspend)
    # executed on suspend
resume)
    # executed on resume
esac
and
sudo chmod +x /etc/pm/sleep.d/20-gvfs
killall nautilus didn't work for me.
I ran :
ps aux |grep nautilus
To list all the process containing nautilus
And I stopped them by using the following command:
kill -9 <PID>
It was rabbitvcs for me. I kill it by using ps aux|grep rabbit and then kill -9 <pid>
It was the rabbitvcs service that stuck the nautilus from time to time.
Carl Cheung
  • 335
You just need to run the following commands
  1. killall nautilus
  2. Open a new terminal and run nautilus
