30
I have a LUKS/LVM volume that was unfortunately removed without being correctly unmounted.
I made a dd backup of my entire encrypted Ubuntu 16.04 installation. Then fresh installation of different Ubuntu version with a live USB inside the LUKS volume on the computer, booted into it, and plugged in the drive with the dd backup to copy data over manually.
It couldn't unlock another drive with the same UUID and encryption key (being a dd backup) and spat the dummy. The drive neither unlocked nor ejected. The drive was then mistakenly cold-yanked while I was trying to find out how to safely remove it.
Now whenever I mount this drive on a different computer, I can unlock without any problem, but when I try to mount the partition inside it says
Error mounting /dev/dm-4 at /media/user/57960113-31ce-4ced-8654-1fadf6012947:
Command-line 'mount -t "ext4" -o "uhelper=udisks2,nodev,nosuid" "/dev/dm-4" "/media/user/57960113-31ce-4ced-8654-1fadf6012947" ' exited with non-zero exit status 32:
mount: mount /dev/mapper/ubuntu1604-ubuntu1604root on /media/user/57960113-31ce-4ced-8654-1fadf6012947 failed:
Structure needs cleaning
This backup is now the only copy of my data. I have dd'd it to another drive so I can experiment without making things worse.
How do I fix this?
Zanna
  • 72,312
in2deep
  • 431
5 Answers5
31
Your file system is broken. You need to fix it so that your OS can properly read/write it.
Therefore, we need to utilise a tool named fsck.
As per it's man page:
Name
fsck - check and repair a Linux file system
Synopsis
fsck [-sAVRTMNP] [-C [fd]] [-t fstype] [filesys...] [--] [fs-specific-options]
Description
fsck is used to check and optionally repair one or more Linux file systems. filesys can be a device name (e.g. /dev/hdc1, /dev/sdb2), a mount point (e.g. /, /usr, /home), or an ext2 label or UUID specifier (e.g. UUID=8868abf6-88c5-4a83-98b8-bfc24057f7bd or LABEL=root). Normally, the fsck program will try to handle filesystems on different physical disk drives in parallel to reduce the total amount of time needed to check all of the filesystems.
A basic usage of the command would be:
sudo fsck.ext4 /dev/sda[NUMBER]
However, do note that this process can be a lengthy one.
Kulfy
  • 18,154
Just as written, you can clean the partition (after a backup, as you already did), by typing
sudo e2fsck /dev/dm-4
e2fsck checks the file system's integrity.
Afterwards, you should be able to mount it again.
serv-inc
  • 3,159
  • 26
  • 32
You can also run gparted. The Partition will be displayed with an exclamation mark.
  • Select in the upper right corner the correct hdd
  • right click on the partition marked with a exclamation mark
  • choose "check"
  • gparted will ask you if you're sure und try to run a repair on the file system. e2fsck. Be aware, that this operation could take some time and you should NOT interrupt it, once it has started.
Cutton Eye
  • 1,256
If your file system type is XFS, then you need to execute the following command:
sudo xfs_repair /dev/to/disk
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
When faced with repeatedly asked questions, you can simply hit 'a' instead of entering 'y' each time. Hitting 'a' answers yes to all. After entering 'a', you'll see a huge number of statements scrolling past your terminal window, so go have dinner or fire up a game or something. This is going to take a few hours!
