My Dell 960 desktop has been running Ubuntu 22.04 for several months without any problems. Suddenly it stopped, and upon restart Grub Rescue came up. I'm unable to redirect boot with LS commands. I used a USB stick with Ubuntu 24.04 to reboot and loaded and ran Boot Repair. The results are at https://paste.ubuntu.com/p/y9cxnbT6rG/ .
============================== Boot Info Summary ===============================
=> Grub2 (v2.00) is installed in the MBR of /dev/sda and looks at sector 1 of the same hard drive for core.img. core.img is at this location and looks for (,msdos1)/boot/grub. It also embeds following components:
modules
fshelp ext2 part_msdos biosdisk
=> Grub2 (v2.00) is installed in the MBR of /dev/sdb and looks at sector 1 of the same hard drive for core.img. core.img is at this location and looks for (hd0,msdos1)/boot/grub. It also embeds following components:
modules
biosdisk fshelp fat exfat ext2 ntfs ntfscomp part_msdos
sda1: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Mounting failed:   mount: /mnt/BootInfo/sda1: mount(2) system call failed: Structure needs cleaning.
   dmesg(1) may have more information after failed mount system call.
sda2: __________________________________________________________________________
File system:       Extended Partition
Boot sector type:  -
Boot sector info:
sda5: __________________________________________________________________________
File system:       swap
Boot sector type:  -
Boot sector info:
sdb1: __________________________________________________________________________
File system:       vfat
Boot sector type:  MSWIN4.1: FAT32
Boot sector info:  No errors found in the Boot Parameter Block.
Operating System:
Boot files:        /boot/grub/grub.cfg /efi/boot/bootx64.efi
                   /efi/boot/grubx64.efi /efi/boot/mmx64.efi
================================ 0 OS detected =================================
================================ Host/Hardware =================================
CPU architecture: 64-bit Video: RV620 PRO [Radeon HD 3470] from Advanced Micro Devices, Inc. [AMD/ATI] Live-session OS is Ubuntu 64-bit (Ubuntu 24.04.1 LTS, noble, x86_64)
===================================== UEFI =====================================
BIOS/UEFI firmware: A06(5.0) from Dell Inc. This live-session is in Legacy/BIOS/CSM mode (not in EFI mode).
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
sda : notGPT, no-BIOSboot, has-noESP, not-usb, not-mmc, no-os, no-wind, 2048 sectors * 512 bytes
Partitions info (1/3): _________________________________________________________
sda1 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, end-after-100GB
Partitions info (2/3): _________________________________________________________
sda1 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, ext4
Partitions info (3/3): _________________________________________________________
sda1 : maybesepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sda
fdisk -l (filtered): ___________________________________________________________
Disk sda: 149.01 GiB, 160000000000 bytes, 312500000 sectors Disk identifier: 0x00039e5f Boot Start End Sectors Size Id Type sda1 * 2048 308375551 308373504 147G 83 Linux sda2 308377598 312498175 4120578 2G 5 Extended sda5 308377600 312498175 4120576 2G 82 Linux swap / Solaris Disk sdb: 14.65 GiB, 15728640000 bytes, 30720000 sectors Disk identifier: 0x001fc462 Boot Start End Sectors Size Id Type sdb1 * 2048 30719951 30717904 14.6G c W95 FAT32 (LBA)
parted -lm (filtered): _________________________________________________________
sda:160GB:scsi:512:512:msdos:ATA ST3160815AS:; 1:1049kB:158GB:158GB:ext4::boot; 2:158GB:160GB:2110MB:::; 5:158GB:160GB:2110MB:linux-swap(v1)::swap; sdb:15.7GB:scsi:512:512:msdos:USB DISK :; 1:1049kB:15.7GB:15.7GB:fat32::boot, lba;
blkid (filtered): ______________________________________________________________
NAME FSTYPE UUID PARTUUID LABEL PARTLABEL sda
├─sda1 ext4 2fb459a8-e6d6-4071-8792-be88c6933883 00039e5f-01
├─sda2 00039e5f-02
└─sda5 swap 90b375f3-9597-4eb8-9611-4d79a726cba1 00039e5f-05
sdb
└─sdb1 vfat A01F-2DAF 001fc462-01 UBUNTU 24_0
Mount points (filtered): _______________________________________________________
                    Avail Use% Mounted on
/dev/sdb1 8.9G 40% /cdrom
Mount options (filtered): ______________________________________________________
/dev/sdb1 vfat ro,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
====================== sdb1/boot/grub/grub.cfg (filtered) ======================
Try or Install Ubuntu Ubuntu (safe graphics) Boot from next volume UEFI Firmware Settings Test memory
==================== sdb1: Location of files loaded by Grub ====================
       GiB - GB             File                                 Fragment(s)
        ?? = ??             boot/grub/grub.cfg                             1
Suggested repair: ______________________________________________________________
The default repair of the Boot-Repair utility would not act on the boot.
The line says "The default repair of the Boot-Repair utility would not act on the boot." I am reluctant to try the advanced mode as I do not want to lose data on the drive if the wrong selections are chosen. Should I
a) Run the advanced mode without checking any options other than those already checked
b) Install Ubuntu 24 over the top of the current installation (do not want to lose other files on disk!)
c) Run other utilities or fixes (please suggest which ones and how to do this). One message in the above Pastebin says:
Is there a way to "clean the structure" without reloading Ubuntu?
karel
  • 122,292
  • 133
  • 301
  • 332
