I just installed 17.04 and I'd like to install this: http://www.noobslab.com/2016/11/macbuntu-1610-transformation-pack-for.html
However the repositories don't work. I think there's a simple trick to adjust the repository to allow installation on Zesty instead of xenial. For example after installing the icon repository and attempting an install this happens:
ole@mkiv:~$ sudo apt-get install macbuntu-os-icons-lts-v8
Reading package lists... Done
Building dependency tree
E: Unable to locate package macbuntu-os-icons-lts-v8
Any idea how to get around this?
Ole
  • 1,527
For those who are using Ubuntu 18.04, you should use the following code:
sudo apt-get install macbuntu-os-ithemes-v1804
Eliah Kagan
  • 119,640
Genes
  • 111
As you say , you can change the PPA Distribution from zesty to yakkety
(not xenial becuase xenial repositories has macbuntu-os-icons-lts-v7 but not macbuntu-os-icons-lts-v8 version).
For this purpose , please follow this path:
Software & Updates > Other software
And then select http://ppa.launchpad.net/noobslab/macbuntu/ubuntu and click on Edit... button.
Then change to Distribution value from zesty to yakkety.
So that's must be worked.
apt-cache search macbuntu-os
macbuntu-os-plank-theme-lts-v8 - These themes is intended to use with Macbuntu by NoobsLab.com
macbuntu-os-ithemes-lts-v8 - MacBuntu Themes available on NoobsLab.com PPA
macbuntu-os-icons-lts-v8 - MacBuntu Icons & cursors uploaded on NoobsLab.com PPA
