First portion of this Answer is taken from here originally posted by Geppettvs D'Constanzo
This command will add 2 percent volume in your existing volume settings
amixer -D pulse sset Master 2%+
and this will reduce it
amixer -D pulse sset Master 2%-
You can also make it 1 percent if you want even granular control over volume and can also add keyboard shortcuts for these commands to use them without terminal and in a reliable way.
Another approach
This is system wide and will not change the workflow (like remembering new custom shortcuts) but for this you'll need to add a PPA to your system to make it work, How to Use a PPA?
sudo add-apt-repository ppa:george-edison55/gnome-settings-daemon
sudo apt-get update
sudo apt-get install unity-settings-daemon
and run upgrade (just in case)
sudo apt-get update
sudo apt-get upgrade
You will need to restart after installation completes. Once the packages have been upgraded, you can use the dconf command to change the volume increment:
dconf write /org/gnome/settings-daemon/plugins/sound/volume-step 2
(The default value is 6.)
Now when you press the volume keys, the volume level should change in increments of 2
Use Ubuntu Gnome 17.04 (or Gnome DE)
What is Default Behaviour of gnome desktop?
this is my output of amixer get Master | grep Mono right now
Playback channels: Mono
Mono: Playback 53 [72%] [-21.00dB] [on]
Output says my volume is now 72% percent, Now I go to the volume slider in Gnome and slide it by just one tick (scroll(er) tick) and now my output is
Mono: Playback 54 [73%] [-20.00dB] [on]
Notice that it changed just 1 percent, that's as fine as it gets.
another thing that I want to point out it is that it (this feature) looks really important to you and if you're willing to take this radical step then their are few major advantages you're looking at
- Unity is already dead, so new patches will most probably not release
- Gnome is gonna be default desktop on Ubuntu 18.04 and beyond making it a good contender to try in 2017
- It also gives you an early preview of things
- and Gnome is really good (personal opinion)
How to install Gnome Shell?
sudo apt install gnome-shell
you'll have an option to choose between Unity and Gnome shell
How to get full Ubuntu Gnome 17.04?
Here you go
More info on Gnome shell
