I want to disable the touchpads on my laptops while typing. This used to be an option in the graphical system settings of Ubuntu but that option is gone in 16.04. I don't recall in which version I saw that option the last time.
These questions and their answers did not help:
- How can I disable touchpad while typing in ubuntu 14.04?
- How can I disable touchpad while typing? On Ubuntu 16.04 syndaemon isn't working
- "Disable Touchpad while typing option" gone in Ubuntu 16.04 LTS
This answer (of yet another question) did actually disable the touchpad (only tried it on one laptop) while I was typing. I then enabled clicking by tapping again (as described in that answer) which also worked ... kind of: When I moved by mouse pointer somewhere using my touchpad and then immediately tapped to click that element, the mouse pointer always jumped back a few millimeters into the direction I moved the mouse pointer from. This means that I always missed what I was intending to click at except when clicking on large elements or intentionally waiting a short moment before tapping (which pissed me off after about a minute).
touchpad-indicator actually disables the touchpad while typing. It does that for 2000 ms after the last key stroke by default which should probably be decreased a lot. The only weird side effect I noticed within the first minute is that it enables circular scroll by default but this can easily be disabled in the settings. So it's already better than all the other options. However, it has huge drawbacks:
- When I type text in Emacs (probably the same for other text editors but I had to write a few pages of text right after I installed it and that that in Emacs), every few minutes, it the cursor randomly jumps up 2 to 8 lines which causes me to mess my text up and really pisses me off. Furthermore, the mouse pointer changes location (It vanishes while typing.) at the same time. This happened many, many times, and it definitely doesn't happen without
touchpad-indicator, so it doesn't appear to be a bug in Ubuntu or Emacs, or a weird hardware malfunction of my keyboard. - After a few hours, the touchpad just stops working. Killing
touchpad-indicatordoesn't make it work again, launching it, again, doesn't, disabling the touchpad and re-enabling it in the system settings doesn't, and disabling it via the FN keys and re-enabling it, doesn't, either. A connected mouse still works. The touchpad works again after the system is rebooted. This happened 2 or 3 times before I purgedtouchpad-indicatorfrom my system. My laptop didn't show this behavior before I installedtouchpad-indicatorand I've been using it for some time since I removed it and this problem is gone. So even though I only have 2 or 3 data points regarding this, I'm pretty sure it'stouchpad-indicator's fault.
Is there a way to disable a laptop's touchpad while typing in Ubuntu 16.04 without weird side effects?
$ xinput
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Logitech Gaming Mouse G502 id=11 [slave pointer (2)]
⎜ ↳ Logitech Gaming Mouse G502 id=12 [slave pointer (2)]
⎜ ↳ Touchpad id=13 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Video Bus id=8 [slave keyboard (3)]
↳ Power Button id=9 [slave keyboard (3)]
↳ Sleep Button id=10 [slave keyboard (3)]
↳ HD WebCam id=14 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=15 [slave keyboard (3)]
↳ Acer WMI hotkeys id=16 [slave keyboard (3)]
