I have the same problem as described here but not enough reputation to comment or answer. Also I've read related questions / solutions.
I'm experiencing random freezes unrelated to a specific activity - sometimes just typing in a terminal. Mouse and keyboard are completely unresponsive but display does refresh. Also ssh sessions continue to work fine.
Initial install was 14.04 where there were no problems. Freezes didn't start immediately after the 16.04 upgrade but many months later (can't tell precisely when anymore) suggesting it's a software issue.
As suggested here and other places I've tried
- moving mouse / keyboard to a different usb port
- upgrading kernel to 4.10, 4.10.rc7, 4.11.rc7 including missing i915 modules to no help
- enabling / disabling additional drivers
- checked swap is enabled
- done the
intel_idle.max_cstate=1trick lightdm restartdoes does not restore mouse and keyboard- reinstall
xserver-xorg - reinstall
xserver-xorg-input-evdev - complete reinstall of xserver
- using the HWE suite
sudo apt install xserver-xorg-hwe-16.04 xserver-xorg-input-all-hwe-16.04
I've checked syslog, kern.log, .xsession-errors, Xorg.0.log. 60s after the freeze and every 60 seconds thereafter I'm seeing the following in Xorg.0.log:
[ 94823.921] (II) config/udev: removing device Logitech USB Optical Mouse
[ 94823.940] (II) evdev: Logitech USB Optical Mouse: Close
[ 94823.940] (II) UnloadModule: "evdev"
[ 94825.607] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/mouse0)
[ 94825.607] (II) No input driver specified, ignoring this device.
[ 94825.607] (II) This device may have been added with another device file.
[ 94825.707] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/event4)
[ 94825.707] (**) Logitech USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[ 94825.707] (II) Using input driver 'evdev' for 'Logitech USB Optical Mouse'
[ 94825.707] (**) Logitech USB Optical Mouse: always reports core events
[ 94825.707] (**) evdev: Logitech USB Optical Mouse: Device: "/dev/input/event4"
[ 94825.764] (--) evdev: Logitech USB Optical Mouse: Vendor 0x46d Product 0xc077
[ 94825.764] (--) evdev: Logitech USB Optical Mouse: Found 12 mouse buttons
[ 94825.764] (--) evdev: Logitech USB Optical Mouse: Found scroll wheel(s)
[ 94825.764] (--) evdev: Logitech USB Optical Mouse: Found relative axes
[ 94825.764] (--) evdev: Logitech USB Optical Mouse: Found x and y relative axes
[ 94825.764] (II) evdev: Logitech USB Optical Mouse: Configuring as mouse
[ 94825.764] (II) evdev: Logitech USB Optical Mouse: Adding scrollwheel support
[ 94825.764] (**) evdev: Logitech USB Optical Mouse: YAxisMapping: buttons 4 and 5
[ 94825.764] (**) evdev: Logitech USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 94825.764] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.0/0003:046D:C077.005D/input/input103/event4"
[ 94825.764] (II) XINPUT: Adding extended input device "Logitech USB Optical Mouse" (type: MOUSE, id 9)
[ 94825.764] (II) evdev: Logitech USB Optical Mouse: initialized for relative axes.
[ 94825.764] (**) Logitech USB Optical Mouse: (accel) keeping acceleration scheme 1
[ 94825.764] (**) Logitech USB Optical Mouse: (accel) acceleration profile 0
[ 94825.764] (**) Logitech USB Optical Mouse: (accel) acceleration factor: 2.000
[ 94825.764] (**) Logitech USB Optical Mouse: (accel) acceleration threshold: 4
What other investigations / solutions can you suggest? I can provide additional info on request.
ADDITIONAL INFO
- both mouse and keyboard are wired not wireless and are plugged directly
- also freezes if I use the 2 USB SS ports.
- 15G swap (none used)
- 1T HDD (70% used)
- X.Org X Server 1.18.4
- xserver-xorg-input-evdev 1:2.10.1-1ubuntu2
- kernel 4.11.0-041100rc7-generic
UPDATE 1 After fiddling with restarting lightdm and plugging the mouse / keyboard in differetn usb ports they started working again. This doesn't always happen though.
UPDATE 2 Switching to HWE has helped somewhat in that the mouse and keyboard would become usable again if I switched USB ports making the system almost entirely usable until today when switching ports didn't help.
