14
Today after I installed Ubuntu 16.04 via USB on my pre-installed Windows 8 machine, I was required to restart my computer. After doing so I wasn't offered to select an OS, so after searching the internet, I came across Boot-Repair which I ran using the Try Ubuntu option in my Ubuntu installation USB.
Following the boot repair I got a message saying,
If your computer directly reboots into Windows, try to change the boot order in your BIOS. If your BIOS does not allow to change the boot order, change the default boot entry of your Windows bootloader. For example, you can boot into Windows then type the following in an admin command prompt:
bcdedit /set {bootmgr} path \EFI\ubuntu\shimx64.efi
After I rebooted my PC, I am receiving the following error message for about 3 seconds, after which it boots automatically into Windows 8, without letting me access Ubuntu.
Error received while booting after manufacturer's logo, before grub:
Failed to open \EFI\BOOT\grubx64.efi - Not Found
Failed to load image \EFI\BOOT\grubx64.efi: Not Found
start_image() returned Not Found
So I tried the other solution of typing that command in the cmd, to which my surprise, worked, and I am now prompted a window (grub) to choose my OS each time I turn on my PC, but unfortunately, I still receive an error each time, that lasts about 3s, after which I can choose my OS (both are working just fine) and work normally.
Do you have any suggestions to get rid of the error message each time I boot my PC?
Jerry
  • 199
6 Answers6
14
Don't try these present above. These are hard and may not work. I also ran into same problem so what I did was took a live USB of Ubuntu and pressed try Ubuntu. Then I went to terminal . There you press this following command .Internet is needed here.
First command: sudo add-apt-repository ppa:yannubuntu/boot-repair && sudo apt update
Second command : sudo apt-get install boot-repair && boot-repair
Then an app will be there. In that you press recommended fix. Then it will fix the grub and reinstall it .here too Internet is must. Then reboot and enjoy dualbooting.
After a Windows update I could no longer boot into Ubuntu: failed to open /EFI/ubuntu/grubx64.efi
I was able to boot using a Live Ubuntu USB, then:
# find the EFI partition
sudo fdisk -l
# mount EFI
sudo mount /dev/<partition_name> /mnt
cp -p /cdrom/EFI/grubx64.efi /mnt/EFI/ubuntu
I had to reboot and enable Secure Boot and that did the trick. This was dual booting 18.04 on a Lenovo Thinkpad t470 with Windows 10
Finally managed to solve it.
For the rest, open the terminal
$ sudo bash
$ cd /boot/efi/EFI
$ sudo cp -p ubuntu/grubx64.efi Boot
$ sudo touch ubuntu/grubx64.efi.gbr
After that, I stopped seeing the error message and grub showed up normally (it did before, too, just after seeing that error message for 3s).
Jerry
  • 199
You should probably fix the boot loader entry itself instead of copying files around. That'll always break when upstream updates something. Try something like this instead:
efibootmgr --create --label Ubuntu --disk /dev/sda1 --loader "\EFI\ubuntu\grubx64.efi"
Where /dev/sda1 corresponds to /boot/efi. For the curious, there's more details in this guide.
bviktor
  • 255
Very similar error occurred with my Ubuntu 20.04 LTS (Focal Fossa) and my Windows 10 on the same SSD, after receiving the latest Windows 10 June 2020 update. The boot menu with grub was gone, the laptop only booted to Windows 10.
**This is how I solved: **I downloaded the Ubuntu ISO, burned to USB drive with Rufus, then booted up the laptop with this USB drive. I selected Try Ubuntu. Open terminal, then set the keyboard
setxkbmap <country_letters>
I was not able to recover the grub using the boot-repair utility, because it complained about a missing EFI partition at the beginning of the disk, which was there indeed.
**Finally this solution worked: ** Check the available partitions
sudo fdisk -l
Disk /dev/nvme0n1: 238,49 GiB, 256060514304 bytes, 500118192 sectors
Disk model: INTEL SSDPEKKF256G7L
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: A1234567-6733-7263-BB45-5E83CFBE3430
Device Start End Sectors Size Type /dev/nvme0n1p1 2048 534527 532480 260M EFI System /dev/nvme0n1p2 534528 567295 32768 16M Microsoft reserved /dev/nvme0n1p3 567296 259842047 259274752 123,6G Microsoft basic data /dev/nvme0n1p4 498069504 500117503 2048000 1000M Windows recovery environment /dev/nvme0n1p5 259842048 481527807 221685760 105,7G Linux filesystem /dev/nvme0n1p6 481527808 498069503 16541696 7,9G Linux swap
Partition table entries are not in disk order.
Mount the EFI System partition, you may check what's there:
sudo mount /dev/nvme0n1p1 /mnt/
sudo ls /mnt/EFI/ubuntu
sudo stat /mnt/EFI/ubuntu/grubx64.efi
File: /mnt/EFI/ubuntu/grubx64.efi Size: 1419128 Blocks: 2776 IO Block: 4096 regular file Device: 10301h/66305d Inode: 14 Links: 1 Access: (0700/-rwx------) Uid: ( 0/ root) Gid: ( 0/ root) Access: 2020-06-25 02:00:00.000000000 +0200 Modify: 2020-06-25 19:24:06.000000000 +0200 Change: 2020-06-25 18:55:30.870000000 +0200 Birth: -
Then copy over the correct grubx64.efi from the USB drive, as recommended by Matthew Hegarty and adrianTNT above.
cp -p /cdrom/EFI/grubx64.efi /mnt/EFI/ubuntu/
Then reboot, remove your USB and you should be fine. (At least I hope I'm fine... :) )
Gabor
  • 95
Just search for the file and copy it to the location in error.
After some updates and power failures, a HP 8200 was complaining about EFI\BOOT\grub64.efi not being found at boot. I put the SSD in another computer (newer motherboard), this booted just fine, maybe it does a search for the .efi files (?!) So I was able to login, I did a search for the missing file name, copied it to the location in error and it booted just fine:
find /boot -name grubx64.efi
/boot/efi/EFI/centos/grubx64.efi
cp /boot/efi/EFI/centos/grubx64.efi /boot/efi/EFI/BOOT/grubx64.efi
The error just said "EFI\BOOT\" but full directory was: "/boot/efi/EFI/BOOT/".
I guess the copy can also be done by putting the hdd in another linux machine.
adrianTNT
  • 233
