Instead of having the Grub menu appear to make a selection of which OS, I get the message:
Failed to open\EFI\ubuntu\grubx64.efi - Not found
Failed to load image \EFI\ubuntu\grubx64.efi: Not found
start_image() returned Not Found, falling back to default
The computer then goes into Windows.
I am a newbie, so please be explicit about any solution. Ubuntu 18.04.
Andra
  • 172
Elinid
I encountered the same problem. I use Windows 11 and Ubuntu 20.04, but I think it might be the similar solution for you.
  1. Create a live USB/disk of Ubuntu
  2. If you are using Windows 10/11, search for change advanced startup options
  3. Advanced Start Up -> Restart Now
  4. Select Use a Device
  5. Select your USB that has Live Ubuntu on it
  6. Select Ubuntu and Select Try Ubuntu
  7. Connect Internet(Wifi)
  8. Open terminal and type:
    sudo add-apt-repository ppa:yannubuntu/boot-repair && sudo apt update
    sudo apt install -y boot-repair && boot-repair
  9. Select Recommended repair
As an alternative solution that I didn't apply:
