I'm having difficulty in adjusting brightness on my Acer Aspire 4740:
  • Screen 14.1-inch glossy LED-backlit, 1366x768 res
  • CPU Intel Core i5-430M 2.26-GHz
  • RAM 1GB DDR3
  • HDD 320GB
  • Graphics Intel GMA HD
Im using Ubuntu 10.10 . I do not have this problem in Ubuntu 10.04 , but this problem occur in Ubuntu 10.10 . I can't decrease or increase my brightness even in Compiz.
Jorge Castro
  • 73,717
Wilsonzaizai
  • 1,163
Try this.
  1. Open the Terminal (Ctrl+Alt+T) and type:
    gksu gedit /etc/default/grub
  2. Change the line:
    GRUB_CMDLINE_LINUX=""
    To:
    GRUB_CMDLINE_LINUX="acpi_osi=Linux"
  3. Save the file and quit the text editor.
  4. Now in the terminal run:
    sudo update-grub
  5. Restart Ubuntu.
Based very closely on this article: living in java
Eliah Kagan
  • 119,640
I also have an ACER, but ASPIRE 4736Z. Same problem.
xbacklight, xgamma doesn't work.
Something that did work for me is redshift utility: Is there a software utility to adjust screen gamma/brightness/contrast?
https://bugs.launchpad.net/emgd/+bug/711172
Add to kernel command line:
acpi_backlight=vendor
And you are done!
Eliah Kagan
  • 119,640
Have you tried using Xbacklight? http://linux.die.net/man/1/xbacklight
Shungun
  • 367
