-2
I'm new to Ubuntu, trying to update Ubuntu 12.04.5 LTS to latest version and unable to do it.
Error:
$ sudo do-release-upgrade -d
Checking for a new Ubuntu release No new release found
Elder Geek
  • 36,752
naren
Personally never had a problem running:
sudo apt-get update
sudo apt-get dist-upgrade
and then reboot.
TheVet
  • 83
Begin by finding an up-to-date mirror near you from this list.
Select the mirror you've chosen by selecting it from Software & Updates Ubuntu software tab as described here
Issue the sudo do-release-upgrade command.
This commadn has a number of switches that modify it's actions that you can review with the command man do-release-upgrade
the -d switch as shown in your post indicates:
Check if upgrading to the latest devel release is possible
Another option is the -p switch which indicates:
Try upgrading to the latest release using the upgrader from Ubuntu-proposed
My preferred method of upgrading is often referred to as the clean install Which includes backing up my home directory (I use a seperate partition for home to make this simple) and Installing fresh the version I want over or alongside if space is available my existing installation.
Elder Geek
  • 36,752
