sudo apt-get upgrade returns:
 linux-image-4.8.0-39-generic
 linux-image-4.8.0-41-generic
 linux-image-generic
 linux-firmware
 linux-signed-image-4.8.0-39-generic
 linux-image-extra-4.8.0-39-generic
 linux-image-4.8.0-37-generic
 linux-image-extra-4.8.0-37-generic
 linux-signed-image-4.8.0-41-generic
 linux-signed-image-4.8.0-37-generic
 linux-signed-image-generic
 linux-image-extra-4.8.0-41-generic
 linux-generic
 linux-signed-generic
 initramfs-tools
I saw the related questions but their errors were a little different. I don't know if that's significant.
Zanna
  • 72,312
Chankin
  • 51
6 Answers6
For me these two lines helped! Just remove all the linux-extra and linux-extra-image files, which are problematic and old.
For each package:
sudo mv /var/lib/dpkg/info/<PACKAGE-NAME>.* /tmp/
Then:
sudo apt-get autoremove && sudo apt-get autoclean
Then install/update the latest linux image file
sudo apt-get install linux-generic
Martin Thornton
  • 5,996
  • 32
  • 43
deb
  • 71
Tengasui,
You can hardly work several kernels from single Ubuntu OS, so I recommend that you put obsolete versions "on hold".
Like this:
sudo apt-mark hold **package_name**
for example
sudo apt-mark hold linux-image-4.8.0-39-generic
Probably you'll need only the latest kernel linux-image-4.8.0-41-generic and associated linux-firmware.
Try also:
dpkg --configure -a
Having single isolated error you can post and we can more know than brazillion of combinations of errors in dozen variants of kernels.
mxdsp
  • 3,988
gmt42
  • 361
I found the problem
apt-get not working on Ubuntu 16.04, problems with kernel packages
It comes from some modifications I had to make to use the Teensy microcontroller
Chankin
  • 51
It is perfectly possible to have multiple kernels. Since only one is used to boot from the others are automatically inactive. It is an advantage to have multiple kernels in case one fails. I have 4 kernels. Since in your case all kernels fail I suspect your drive or partition is out of space or has not sufficient space left.
wie5Ooma
  • 1,849
you sources.list file in /etc/apt/ directory is corrupted please do following things that will do everything for you guys.
//first remove the source.list file don't worry
      rm /etc/apt/sources.list
and then run this command in the terminal
sudo software-properties-gtk
and this would create a sources.list file automatically. then run this
sudo apt -f install
Best regards ... Mehdi Filban
I had a problem like this, which happened during a fresh install of ubuntu. It happened because my boot partition was too small (100MB), and the installation wasn't able to copy all the files it needed.
FIX: enlarge the boot partition to 200MB, and then reinstall.
