Any time I try to install anything with apt-get I get this error
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
kde-l10n-engb linux-image-4.4.0-21-generic
linux-image-extra-4.4.0-21-generic
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 483 not upgraded.
8 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up linux-image-4.4.0-31-generic (4.4.0-31.50) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
The link /initrd.img is a dangling linkto /boot/initrd.img-4.4.0-28-generic
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.4.0-31-generic /boot/vmlinuz-4.4.0-31-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.4.0-31-generic /boot/vmlinuz-4.4.0-31-generic
update-initramfs: Generating /boot/initrd.img-4.4.0-31-generic
cp: omitting directory '/etc/udev/rules.d/49-teensy.rules'
E: /usr/share/initramfs-tools/hooks/udev failed with return 1.
update-initramfs: failed for /boot/initrd.img-4.4.0-31-generic with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-4.4.0-31-generic.postinst line 1052.
dpkg: error processing package linux-image-4.4.0-31-generic (--configure):
subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of linux-image-extra-4.4.0-31-generic:
linux-image-extra-4.4.0-31-generic depends on linux-image-4.4.0-31-generic; however:
Package linux-image-4.4.0-31-generic is not configured yet.
dpkg: error processing package linux-image-extra-4.4.0-31-generic (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-image-generic:
linux-image-generic depends on linux-image-4.4.0-31-generic; however:
linux-image-generic depends on linux-image-extra-4.4.0-31-generic; however:
Package linux-image-extra-4.4.0-31-generic is not configured yet.
dpkg: error processing package linux-image-generic (--configure):
dpkg: dependency problems prevent configuration of linux-generic:
linux-generic depends on linux-image-generic (= 4.4.0.31.33); however:
Package linux-image-generic is not configured No apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
yet.
dpkg: error processing package linux-generic (--configure):
Setting up linux-image-4.4.0-24-generic (4.4.0-24.43) ...
Running depmod.
The link /initrd.img is a dangling linkto /boot/initrd.img-4.4.0-31-generic
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.4.0-24-generic /boot/vmlinuz-4.4.0-24-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.4.0-24-generic /boot/vmlinuz-4.4.0-24-generic
update-initramfs: Generating /boot/initrd.img-4.4.0-24-generic
update-initramfs: failed for /boot/initrd.img-4.4.0-24-generic with 1.
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-4.4.0-24-generic.postinst line 1052.
dpkg: error processing package linux-image-4.4.0-24-generic (--configure):
Setting up linux-image-4.4.0-28-generic (4.4.0-28.47) ...
Running depmod.
The link /initrd.img is a dangling linkto /boot/initrd.img-4.4.0-24-generic
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.4.0-28-generic /boot/vmlinuz-4.4.0-28-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.4.0-28-generic /boot/vmlinuz-4.4.0-28-generic
update-initramfs: Generating /boot/initrd.img-4.4.0-28-generic
update-initramfs: failed for /boot/initrd.img-4.4.0-28-generic with 1.
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-4.4.0-28-generic.postinst line 1052.
dpkg: error processing package linux-image-4.4.0-28-generic (--configure):
dpkg: dependency problems prevent configuration of linux-image-extra-4.4.0-24-generic:
linux-image-extra-4.4.0-24-generic depends on linux-image-4.4.0-24-generic; however:
Package linux-image-4.4.0-24-generic is not configured yet.
dpkg: error processing package linux-image-extra-4.4.0-24-generic (--configure):
dpkg: dependency problems prevent configuration of linux-image-extra-4.4.0-28-generic:
linux-image-extra-4.4.0-28-generic depends on linux-image-4.4.0-28-generic; however:
Package linux-image-4.4.0-28-generic is not configured yet.
dpkg: error processing package linux-image-extra-4.4.0-28-generic (--configure):
linux-image-generic
linux-generic
sudo dpkg --configure -a
gives the same result
