I just upgraded to Ubuntu 18.04 from 16.04. However, I am getting this error with respect to miktex:
Removing miktex (2.9.6650-1) ...
miktexsetup: /usr/lib/x86_64-linux-gnu/libcurl.so.4: version
`CURL_OPENSSL_3' not found (required by miktexsetup)
dpkg: error processing package miktex (--remove):
installed miktex package pre-removal script subprocess returned error exit status 1
miktex
At this time, it seems miktex has not yet been updated to work with Ubuntu 18.04. I recommend using texlive instead:
sudo aptitude install texlive
You can remove the miktex package:
sudo aptitude -f remove miktex
However, fully removing miktex is more complicated because the package is just an installer. If you installed it in your home directory, look in ~/bin for remnants. Otherwise look in /usr/local/bin.
xiota
  • 5,038
