53
I am using Virtual Box 5.1 on top of Windows 7 Host OS with Ubuntu 14.04 LTS Guest OS. I have already installed VBOXADDITIONS_5.1.14_112924 and restarted the Guest machine. The folder appears as mounted underneath the Devices in Files, and it appears as shared on the Host machine.
What permissions do I need to change on my Host/Guest OS to make this shared folder work?
You have to add yourself to the shared folders group in the Ubuntu guest.
sudo adduser $USER vboxsf
Guest OS needs to be restarted after this.
Bora
  • 226
If you get
'Username' is not in the sudoers file. This incident will be reported
then use
su root
then you can proceed with as suggested by Bora.
