I'm having a strange problem after upgrading my ASUS 1215N from Ubuntu 16.04 to 16.10 (Unity 7).
Basically only Fn + F1..F6 combinations worked properly, all Fn + F7..F12 didn't even showed up in acpi_listen.
I've tried modifying GRUB configuration file as suggested here, adding acpi_osi= and most important keys now work, but there are still glitches.
Follows a resume of acpi_listen events when pressing each key combination, highlighting those not working.
I haven't tried creating 20-intel.conf file because the netbook is equipped with two graphic cards and I'm not sure that that fix would work with the discrete one.
acpi_backlight=vendor creates more problem than it solves.
Last version of BIOS installed (0902).
acpi_listen results in this:
Fn + F1: standby, works well
button/sleep SBTN 00000080 00000000 button/sleep PNP0C0E:00 00000080 00000001Fn + F2: toggle WiFi, no notification
# Was ON, turns OFF hotkey ASUS010:00 00000010 00000000 button/wlan WLAN 00000080 00000000 K ------------------------------------------- # Was OFF, turns ON hotkey ASUS010:00 00000010 00000001 button/wlan WLAN 00000080 00000000 KFn + F3: nothing assigned
^[ORFn + F4: nothing assigned
^[OSFn + F5, Fn + F6: brightness down / brightness up
Used to work correctly before
acpi_osi=, now it still works but no notification is shown on the desktop.Following an example going from brightness lowest to highest e backwards. As you can see brightness values range from
00000020to0000002a.hotkey ASUS010:00 00000020 00000041 hotkey ASUS010:00 00000020 00000042 hotkey ASUS010:00 00000021 00000007 hotkey ASUS010:00 00000022 00000008 hotkey ASUS010:00 00000023 00000007 hotkey ASUS010:00 00000024 00000006 hotkey ASUS010:00 00000025 00000006 hotkey ASUS010:00 00000026 00000006 hotkey ASUS010:00 00000027 00000006 hotkey ASUS010:00 00000028 00000006 hotkey ASUS010:00 00000029 00000006 hotkey ASUS010:00 0000002a 00000037 hotkey ASUS010:00 0000002a 00000038 hotkey ASUS010:00 0000002a 00000039 hotkey ASUS010:00 0000002a 0000003a hotkey ASUS010:00 0000002a 0000003b hotkey ASUS010:00 0000002a 0000003c hotkey ASUS010:00 0000002a 0000003d hotkey ASUS010:00 00000029 00000007 hotkey ASUS010:00 00000028 00000007 hotkey ASUS010:00 00000027 00000007 hotkey ASUS010:00 00000026 00000007 hotkey ASUS010:00 00000025 00000007 hotkey ASUS010:00 00000024 00000007 hotkey ASUS010:00 00000023 00000008 hotkey ASUS010:00 00000022 00000009 hotkey ASUS010:00 00000021 00000008 hotkey ASUS010:00 00000020 00000043 hotkey ASUS010:00 00000020 00000044 hotkey ASUS010:00 00000020 00000045 hotkey ASUS010:00 00000020 00000046Fn + F7: turn display OFF, doesn't work in any configuration
hotkey ASUS010:00 00000016 00000000 video/displayoff DOFF 00000089 00000000 KFn + F8: switch video mode (presentation I guess), doesn't work thought I'm not sure what it should do
hotkey ASUS010:00 00000030 00000000 video/switchmode VMOD 00000080 00000000 KFn + F9: toggle trackpad, doesn't work (multiple press)
hotkey ASUS010:00 00000037 00000001 hotkey ASUS010:00 00000037 00000002 hotkey ASUS010:00 00000037 00000003 hotkey ASUS010:00 00000037 ........Fn + F10: mute, works now (multiple press)
hotkey ASUS010:00 00000013 00000001 button/mute MUTE 00000080 00000000 K hotkey ASUS010:00 00000013 00000002 button/mute MUTE 00000080 00000000 K hotkey ASUS010:00 00000013 00000003 button/mute MUTE 00000080 00000000 K hotkey ASUS010:00 00000013 ........ button/mute MUTE 00000080 00000000 KFn + F11, Fn + F12: volume down / volume up, works after
acpi_osi=hotkey ASUS010:00 00000014 0000002d button/volumedown VOLDN 00000080 00000000 K hotkey ASUS010:00 00000015 00000023 button/volumeup VOLUP 00000080 00000000 K
