I have an Asus N56JK computer and I have tried many different options such as updating the Grub file in /etc/default/grub but to no avail. All other Function keys seems to be working but only function keys used to adjust brightness are not working?
Mudit Kapil
  • 2,081
I have a Asus X551MA, here is what worked for me.
Update Grub;
  1. Open terminal with Ctrl+Alt+T
  2. type in terminal;
    gksudo gedit /etc/default/grub
  3. Change;
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
    to
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash pcie_aspm=force acpi_osi="
  4. Save and Exit gedit
  5. type in terminal;
    sudo update-grub
  6. Restart your computer; (Don't forget to bookmark this page)
    sudo shutdown -r now
    This should fix your issue, if not keep reading.
Create 20-intel.conf; Intel GFX card only!
    cd /usr/share/X11/xorg.conf.d
  3. now;
    sudo touch 20-intel.conf
  4. then type;
    gksudo gedit 20-intel.conf
  5. Copy & Paste the following lines into the document;
    Section "Device"
        Identifier "card0"
        Driver "intel"
        Option "Backlight" "intel_backlight"
        BusID "PCI:0:2:0"
    EndSection
  6. Save and Exit the document.
  7. Restart your computer;
    This should work, if not keep reading.
Install 3.16 kernel for 14.04 LTS;
  1. Update;
    sudo apt-get update
  2. Install;
    sudo apt-get install linux-image-generic-lts-utopic
That's all I got, sorry if this is incompatible with your set-up as there may be additional steps required, and I prefer to refrain from giving blind advice. I do recommend upgrading the kernel however, as this may be the solution you need, if you are using Ubuntu 14.10 or later there is no need to upgrade the kernel.
proxe
  • 319
I have an ASUS UX305FA zenbook and the above suggestions re: messing around with /etc/default/grub ddidn't work for me.
This worked for me: https://github.com/thezerobit/asus-zenbook-ux305fa
Install xbacklight
sudo apt-get install xbacklight
In Keyboard settings, set up custom shortcuts to increase or decrease backlight by calling xbacklight -inc 10 or xbacklight -dec 10.
Edit: I own this laptop too and the xbacklight workaround does work. you should just not use the fn + f5/f6 buttons but use other keys, mine are ctrl + f3/f4. Also if i decrease too much, the screen will go entirely black..
