184
My Dell laptop (XPS 15z) has special keys on the F1 to F12 keys. If I want to disable keyboard backlight, for example, I must type Fn + F6.
  • Is it possible to invert it?
In fact, I don't often use the F* keys.
  • How can I only hit F6 to disable the backlight and Fn + F6 to type F6?
  • Is it possible?
Thanks.
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
Gp2mv3
  • 2,054
I am not sure if it works for all models, but on mine if you press Fn+Esc it changes the Fn lock so that F1+F12 work as normal and when you hold Fn+(lets say F11) it will change the brightness or whatever that keys secondary function is. Pressing Fn+Esc again reverts it back to default. Hope this helps.
KGIII
  • 4,101
Shy
  • 4,256
64
It should be possible to do it in the BIOS. Quoting the XPS 15z manual:
  1. Press F2 during POST (Power On Self Test) to enter the System Setup (BIOS) utility.
  2. In the Function Key Behavior, select Multimedia Key First or Function Key First.
    • Function Key First — This is the default option. Press any function key to perform the associated function. For multimedia action, press Fn + the required multimedia key.
    • Multimedia Key First — Press any multimedia key to perform the associated multimedia action. For function, press Fn + the required function key.
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
roadmr
  • 34,802
On mine, the problem was that the NumLk key had been pressed. Pressing it again holding the Fn key reverted the Fn key back.
