I am trying to copy the contents of a folder to another folder in a different directory using terminal.
Would somebody be able to provide me an example of the command line syntax required to achieve this?
You can copy the contents of a folder /source to another existing folder /dest with the command:
cp -a /source/. /dest/
The -a option is an improved recursive option, that preserves all file attributes and symlinks.
The . at end of the source path is a specific cp syntax that copies all files and folders, including hidden ones.
Lets say you have a folder called folder1 in your ~, inside folder1 is 1 file called file1 and 2 folders called sub1 and sub2 each with other files and folders inside them.
To copy all the contents of ~/folder1 to ~/new_folder1 you would use
cp -r ~/folder1/. ~/new_folder1
new_folder1 would then contain all the files and folders from folder1.
cp is the command to copy using a terminal, -r makes it recursively (so, current directory + further directories inside current) ~/folder1 is the origin folder, ~/new_folder1 is the destination folder for the files/folders inside the origin.
Copy the directory dir_1 and its contents (files) into directory dir_2:
cp -r ./dir_1 ./dir_2
# or
cp -r ./dir_1/ ./dir_2/
# Results in: ./dir_2/dir_1/_files_
Copy only the contents (files) of dir_1 into directory dir_2:
cp -r ./dir_1/. ./dir_2
# or
cp -r ./dir_1/. ./dir_2/
# Results in: ./dir_2/_files_
_files_ is a placeholder for the actual files located in the directory.
Check this http://www.cyberciti.biz/faq/copy-folder-linux-command-line/ for more information on copying folder. Hope this helps.
cp Command
cp is a Linux command for copying files and directories. The syntax is as follows:
cp source destination
cp dir1 dir2
cp -option source destination
cp -option1 -option2 source destination
In this example copy /home/vivek/letters folder and all its files to /usb/backup directory:
cp -avr /home/vivek/letters /usb/backup
Where,
-a : Preserve the specified attributes such as directory an file mode, ownership, timestamps, if possible additional attributes: context, links, xattr, all.
-v : Explain what is being done.
-r : Copy directories recursively.
Example
Copy a folder called /tmp/conf to /tmp/backup:
$ cp -avr /tmp/conf/ /tmp/backup
This code with Flag "-R" copies perfectly all the contents of "folder1" to existing "folder2":
cp -R folder1/. folder2
Flag "-R" copies symbolic links as well but Flag "-r" skips symbolic links so Flag "-R" is better than Flag "-r".
-R, --dereference-recursive
For each directory operand, read and process all files in that directory,
recursively, following all symbolic links.
-r, --recursive
recursively. Follow symbolic links on the command line, but skip symlinks
that are encountered recursively. Note that if no file operand is given,
grep searches the working directory. This is the same as the
‘--directories=recurse’ option.
I like this command
rsync -av --progress ~/code/project-source/. ~/code/project-destination --exclude .git --exclude node_modules
Some of the commonly used options in rsync command are listed below:
If there are two folders: (with write permission)
drwxr-xr-x 4 vimal vimal 4096 Sep 9 12:17 .
drwxr-xr-x 3 root root 4096 Aug 18 14:35 ..
drwxrwxrwx 6 vimal vimal 4096 Sep 9 12:15 DATA
drwxrwxrwx 7 vimal vimal 4096 Sep 9 12:15 PORTAL
If you are inside the folder called PORTAL where you want to copy all content of another folder say DATA at the same level then you will do
vimal@vimal-D3H:/var/www/html/PORTAL$ cp -a ../DATA/. .
You have to notice 2 dots. Last dot says copy here in present folder
and
one following /DATA/. says that all the CONTENTS inside DATA folder to be copied, and not the DATA folder itself.
If you remove this trailing "." from /DATA/
then whole DATA folder will be copied inside PORTAL(from where you are coping).
