-6
I have 7000 files I would like to copy to a folder from home/Videos to /usr/share/someplace. How do I do this?
If you want to copy all the files in the Videos folder to /usr/share/someplace, run this command:
sudo cp -R ~/Videos/* /usr/share/someplace
Keep in mind that /usr/share/someplace must exist so if you need to create that file before you start, run this command first:
sudo mkdir /usr/share/someplace
If you want to move all those files, you can use the mv command instead of cp.
mchid
  • 44,904
  • 102
  • 162
You can also use -v option so u can see all the files that are copying.As
cp -rv ~/Videos/* /usr/share/someplace
OR
You can tar the files and copy them as:
tar -cvzf /usr/share/someplace/allfiles.tar.gz ~/Videos/* ....
muru
  • 207,228
