I want to know how to copy a folder from a desktop to an external disk like pen-drive using terminal in Ubuntu 16.04.
The name of the disk is /dev/sdb1 in my system.
What is the exact command for copying a folder into the pen-drive?
There are two questions which need to be answered:
The command to copy a folder is cp -r (a recursive copy)
You'll have to identify the path of your pen-drive.
If the pen-drive uses device /dev/sdb1, you will be able to get the path to the pen-drive (the mount point) using the df
The output of df looks like this:
df
Filesystem 1K-blocks Used Available Use% Mounted on
udev 16405712 0 16405712 0% /dev
tmpfs 3285172 141288 3143884 5% /run
/dev/sdb1 449093384 72712024 353545700 18% /
tmpfs 16425844 290220 16135624 2% /dev/shm
tmpfs 5120 4 5116 1% /run/lock
tmpfs 16425844 0 16425844 0% /sys/fs/cgroup
tmpfs 3285172 168 3285004 1% /run/user/1000
/dev/sdc1 976759804 389531656 587228148 40% /mnt/hddc1
hence if the device you'd like to use is /dev/sdc1 , the mount-point is /mnt/hddc1
For example, if you need to copy from /home/user/Desktop/folderName to pen-drive on sdc1 , the command will be:
cp -r /home/user/Desktop/folderName /mnt/hddc1
