First off, let me start by saying that I am well aware that many other people have asked similar questions, and have had their questions answered and their problems solved. I am here because I have attempted a range of the solutions already posted, and none of them have worked.
Some background: I am running Ubuntu 16.04 off of a flash drive. The WiFi does not work. But, it's not just that I try to connect to a network, and it doesn't connect; rather, the idea of WiFi itself seems to be a foreign concept to the system. Nowhere is there any option to even see available WiFi networks. Clicking on the network icon yields: (parentheses indicate grayed-out):
(Ethernet network)
(disconnected)
VPN Connections→
Enable Networking – this is checked
(Connection information)
Edit connections
If I run service network-manager restart, which some guides say will fix the wifi menu, I get a notification that I am now disconnected, and more options become grayed out. I've also tried typing nm-applet in terminal and that did nothing.
One post suggested running sudo ifconfig wlp4s0 up. This did nothing, and gave the message: wlp4s0: ERROR while getting interface flags: no such device.
Running sudo modprobe -wl yields: Error: Could not insert wl: required key not available. Researching that, it seems that the error comes from having secure boot enabled. So I go into the BIOS, disable secure boot, and then run the command again, and get the same result.
After disabling secure boot, I then tried running sudo apt-get purge bcmwl-kernel-source then sudo apt-get install linux-generic bcmwl-kernel-source, rebooted, and there was no effect.
My wifi card is Broadcom BCM4312 802.11b/g/n and my PCI Id is 14e4:4365 (rev 01). This information in hand, I followed the instructions of another post, which suggested I go to /etc/pm/config and edit config.d, adding SUSPEND_MODULES="BCM4312". There was no config.d file in that directory, and I was told I did not have permission to save a file there, which makes no sense because I am the only user.
I've gone into Settings > Software and Updates, and enable the Broadcom wifi card.
Output of iwconfig:
lo    no wireless extensions
enp14s0   no wireless extensions
I'm not sure what that means.
I've tried all the steps at the following posts:
And non of them seem to work. I am not sure where to go from here. Any help would be greatly appreciated. Thank you.
Dan V
