I am running Ubuntu 16.10 and during setup I added my data drive which is ntfs, to automount in /etc/fstab file. The entry looks like this -
UUID=EA469A60469A2D77   /alpha  ntfs-3g rw,permissions,umask=0022,user,exec,uid=1000,gid=1000,locale=en_US.UTF-8  0       0
I would like to know what I am doing wrong and how to get write access to the mounted NTFS partition.
EDIT1:
prenx@prenx4x:~$ sudo lsblk -o NAME,FSTYPE,SIZE,MOUNTPOINT,LABEL
NAME   FSTYPE   SIZE MOUNTPOINT LABEL
sdb           111.8G
├─sdb2 swap    18.6G [SWAP]
└─sdb1 ext4    93.2G /
sdc             3.7T
├─sdc2 ntfs     3.7T /zeta      Zeta
└─sdc1          128M
sda           953.9G
├─sda4 ntfs   952.9G /alpha     ALPHA
├─sda2 vfat      99M
├─sda5 ntfs     450M
├─sda3          128M
└─sda1 ntfs     300M            Recovery
After changing any option I test it using mkdir-
prenx@prenx4x:/alpha$ mkdir a
mkdir: cannot create directory ‘a’: Read-only file system
prenx@prenx4x:/alpha$ sudo mkdir a
Also I am unable to paste or create anything in any sub-folder as well.
The Prenx
  • 355
If the NTFS drives are mounting as read-only, its probably because Ubuntu thinks their filesystems are unclean, probably due to hibernation, or a damaged file system. Do this:
in Windows
  • boot into Windows
  • open the Power control panel
  • choose change what the power buttons do
  • choose change options that are unavailable
  • uncheck fast startup
  • close the Power control panel
  • open an administrative command prompt window
  • type powercfg /h off
  • type chkdsk /f c:
  • approve to run chkdsk at next reboot
  • type chkdsk /f x: (replacing "x" with drive letters of other visible NTFS partitions)
  • reboot into Windows to let chkdsk run on drive C:
heynnema
  • 73,649
Using rw, permissions, umask=0022, user, exec, uid=1000, and gid=1000 seems excessive.
The Official Documentation is pretty straight forward.
Something like this should work for your purposes:
UUID=EA469A60469A2D77 /alpha ntfs-3g defaults,windows_names,locale=en_US.utf8 0 0
AnotherKiwiGuy
  • 4,482
  • 22
  • 39
