I am new to Ubuntu. I installed Ubuntu 18.10.
I have 6 NTFS partitions And I want to get all access to those drives. I cannot paste, create or delete anything from those drives. Is it possible? If it is possible, how?
My fstab description is
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sdb6 during installation
UUID=dc354829-f570-432c-8dbc-b5f64d498e1d /               ext4    errors=remount-ro 0       1
# /home was on /dev/sdb7 during installation
UUID=aee32533-8486-402b-9e64-7970f429e12d /home           ext4    defaults        0       2
# swap was on /dev/sdb5 during installation
UUID=fd8aab6e-8423-421e-a33b-590b15938c06 none            swap    sw              0       0
and blkid is:
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/loop4: TYPE="squashfs"
/dev/loop5: TYPE="squashfs"
/dev/loop7: TYPE="squashfs"
/dev/sda1: LABEL="System Reserved" UUID="04CE3588CE357352" TYPE="ntfs" PARTUUID="305a33dd-01"
/dev/sda2: LABEL="Windows" UUID="E0FE39DFFE39AF22" TYPE="ntfs" PARTUUID="305a33dd-02"
/dev/sda3: UUID="180276320276154A" TYPE="ntfs" PARTUUID="305a33dd-03"
/dev/sdb1: LABEL="System File {Don't Open it pls}" UUID="01D362CEDE257C60" TYPE="ntfs" PARTUUID="e3d2bf96-01"
/dev/sdb2: UUID="01D362CEE07E1260" TYPE="ntfs" PARTUUID="e3d2bf96-02"
/dev/sdb3: LABEL="TV Serise" UUID="01D368208E4E61A0" TYPE="ntfs" PARTUUID="e3d2bf96-03"
/dev/sdb5: UUID="fd8aab6e-8423-421e-a33b-590b15938c06" TYPE="swap" PARTUUID="e3d2bf96-05"
/dev/sdb6: UUID="dc354829-f570-432c-8dbc-b5f64d498e1d" TYPE="ext4" PARTUUID="e3d2bf96-06"
/dev/sdb7: UUID="aee32533-8486-402b-9e64-7970f429e12d" TYPE="ext4" PARTUUID="e3d2bf96-07"
/dev/sdc1: LABEL="New Volume" UUID="305C47EF5C47AF02" TYPE="ntfs" PARTUUID="5a6c94e8-01"
/dev/sdc2: LABEL="2 software" UUID="719487CC26DAD33E" TYPE="ntfs" PARTUUID="5a6c94e8-02"
/dev/sdc3: LABEL="3" UUID="A6AEB439AEB40439" TYPE="ntfs" PARTUUID="5a6c94e8-03"
/dev/sdc4: LABEL="Movie" UUID="0A8B231E3AED0A2E" TYPE="ntfs" PARTUUID="5a6c94e8-04"
/dev/loop8: TYPE="squashfs"
/dev/loop9: TYPE="squashfs"
/dev/loop10: TYPE="squashfs"
/dev/loop11: TYPE="squashfs"
/dev/loop12: TYPE="squashfs"
/dev/loop13: TYPE="squashfs"
/dev/loop14: TYPE="squashfs"
/dev/loop15: TYPE="squashfs"
/dev/loop16: TYPE="squashfs"
/dev/loop17: TYPE="squashfs"
/dev/loop19: TYPE="squashfs"
/dev/loop20: TYPE="squashfs"
/dev/loop21: TYPE="squashfs"
karel
  • 122,292
  • 133
  • 301
  • 332
Salim
  • 31
NTFS has been something a lot of people have had issues with, and as such there are a lot of questions already about this topic.
This is a permission issue, where your user do not have permission to write to these partitions/drives.
Please have a look at these:
pomsky
  • 70,557
garshol
  • 136
