I know this question was proposed in the past but I tried almost everything. I don't know if my problem is more complicated or I am missing something.
In my computer I have a big ntfs partition in which I keep files both for windows 10 and ubuntu. When I set the thing the first time I already had problems to write on it using linux but with the guides I managed to fix it. The problem is that I lost the ability to write again and I don't know why. I already tried to manually modify fstab and to use NTFS configuartion tool to set the permissions.
This is my fstab file; the partition is sda7
# /etc/fstab: static file system information.
# <file system> <mount point> <type> <options> <dump> <pass>
#Entry for /dev/sda5 :
UUID=4f83e373-2a7d-442b-8ad3-8d5929a8ddaa / ext4 errors=remount-ro 0 1
#Entry for /dev/sda1 :
UUID=080EEE880EEE6E5E /media/Riservato_per_il_sistema ntfs-3g defaults,locale=en_US.UTF-8 0 0
#Entry for /dev/sda7 :
UUID=6BB0D79157E7DFD1 /media/Storage/ ntfs-3g defaults,nodev,nosuid,locale=en_US.UTF-8 0 0
#Entry for /dev/sda2 :
UUID=B01EF20D1EF1CC7A /media/sda2 ntfs-3g defaults,locale=en_US.UTF-8 0 0
#Entry for /dev/sda6 :
UUID=8c082106-53f1-409c-8347-df226cd0b95d none swap sw 0 0
I also tried to modify the ownership with
cd /media/Storage/
sudo chown -R -v username:username *
but the result was this answer for every file and folder
chown: changing ownership of 'Windows': Read-only file system
failed to change ownership of 'Windows' from root:root to username:username
Is someone able to give me any suggestion?
EDIT: output of blkid aftes step1
/dev/sda1: LABEL="Riservato per il sistema" UUID="080EEE880EEE6E5E" TYPE="ntfs" PARTUUID="fd65e542-01"
/dev/sda2: UUID="B01EF20D1EF1CC7A" TYPE="ntfs" PARTUUID="fd65e542-02"
/dev/sda5: UUID="4f83e373-2a7d-442b-8ad3-8d5929a8ddaa" TYPE="ext4" PARTUUID="fd65e542-05"
/dev/sda6: UUID="8c082106-53f1-409c-8347-df226cd0b95d" TYPE="swap" PARTUUID="fd65e542-06"
/dev/sda7: LABEL="Storage" UUID="6BB0D79157E7DFD1" TYPE="ntfs" PARTUUID="fd65e542-07"
EDIT2:fstab at the beginning of step#3
#UUID=080EEE880EEE6E5E /media/Riservato_per_il_sistema ntfs-3g defaults,locale=en_US.UTF-8 0 0
#/dev/sda7 /media/Storage ntfs-3g defaults,nodev,nosuid,locale=en_US.UTF-8 0 0
#/dev/sda7 /media/Storage/_ ntfs-3g defaults,nodev,nosuid,locale=en_US.UTF-8 0 0
#UUID=B01EF20D1EF1CC7A /media/sda2 ntfs-3g defaults,locale=en_US.UTF-8 0 0
