Background
I had a similar problem during suspend/resume when sound would switch from HDMI TV to laptop speakers. Upon resume sound would stay on Laptop speakers and I would have to manually reset output device to TV in System Settings -> Sound.
This was one of my first annoying experiences with upgrade from Ubuntu 14.04 to 16.04 and the root was upgrade to PulseAudio 8 that comes with 16.04 LTS
After much searching I created a script called TV-sound. Although I don't plug and unplug the TV like yourself, I did some google searches and create a variation of the script to work in your situation. I've tested it and it works.
Step 1: Create script to switch audio between connected devices
We'll create a script called hotplugtv which udev calls. This same script can be called in many places though. For example, during testing I used it in lock-screen-timer where sound reverted back to Laptop during screen lock.
cd /usr/local/bin
sudo touch hotplugtv
sudo chmod +x hotplugtv
gksu gedit hotplugtv
When the editor opens with a blank screen, copy and paste the following into it:
#! /bin/bash
# NAME: hotplugtv
# PATH: /usr/local/bin
# DESC: Update pulseaudio output device when HDMI TV plugged / unplugged
# CALL: called from /etc/udev/rules.d/99-monitor-hotplug.rules
# DATE: Created Nov 26, 2016.
# NOTE: logs output using log-file
# UPDT: Dec 14, 2016 - Sometimes /sys/class/drm/card0 & sometimes /sys/class/drm/card1
# so use /sys/class/dmcard* instead.
if [[ $(cat /sys/class/drm/card*-HDMI-A-1/status | grep -Ec "^connected") -eq 1 ]]; then
# log-file "HDMI TV connected" ~/bin/log-hotplugtv;
/bin/sleep 2;
export PULSE_RUNTIME_PATH="/run/user/1000/pulse/";
sudo -u rick -E pacmd set-card-profile 0 output:hdmi-stereo;
else
# log-file "HDMI TV disconnected" ~/bin/log-hotplugtv;
sudo -u rick -E pacmd set-card-profile 0 output:analog-stereo;
fi
exit 0
You will need to replace the two occurrences of rick with your own user id, ie UTF-8, etc.
I know this can be more professional with user name automatically set to a bash variable but I'm not that skilled yet :( Anyway, save the file and exit gedit.
Step 2: Create udev rules
udev monitors hotplug events when you plug in and unplug your HDMI monitor. Type the following to create a new rule.
cd /etc/udev/rules.d
sudo cp 70-persistent-net.rules 99-hotplugtv.rules
gksu gedit 99-hotplugtv.rules
NOTE: If the file 70-persistent-net.rules doesn't exist in your directory copy any other file there. We don't need the file contents,
just the file permissions to ensure ours are the same.
The editor will show a bunch of irrelevant text, highlight it and delete it. Then highlight the code below and paste it into the editor:
# NAME: 99-hotplugtv.rules
# PATH: /etc/udev/rules.d
# CALL: automatically called on system events
# NOTE: in future may requre systemd service hooks
ACTION=="change", SUBSYSTEM=="drm", ENV{HOTPLUG}=="1", RUN+="/usr/local/bin/hotplugtv"
Save the file and exit.
To enable the rule (without rebooting) we need to reload udev:
sudo udevadm control --reload-rules
Now you can plug and unplug your HDMI monitor / TV and the sound switches appropriately.
Caveat
On my system the sound automatically reverts to the Laptop speakers when HDMI is unplugged. On your system it did not. Further enhancements to the code may be required if sound doesn't go to your Laptop speakers when HDMI is unplugged. Please reply via comment below how things work / don't work out.
Quick testing in CLI
You can quickly test the code at the terminal by using:
Switch to HDMI / TV:
Switch back to built in speakers:
Remember to replace rick with your user name.
- The initial
export line probably isn't necessary but I've included it just to be safe.
- If you have multiple sound cards, or something other than
hdmi-stereo tweaks are obviously needed to find out the correct parameters before writing your script.
Deciphering your device name within PulseAudio
The code below uses the same command twice. Once when the sound is set to external HDMI TV. A second time when the sound is set to the Laptop's built in speakers. Each time you see the name PulseAudio uses:
$ pacmd list-sinks | grep -e 'name:' -e 'index'
* index: 28
* index: 30
When you have multiple sound cards
Use the command aplay -l to see if you have cards greater than number 0. If so you will need to use appropriate card number in your scripts. For example:
$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: 92HD91BXX Analog [92HD91BXX Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 0/1
In the above example all card numbers are 0 with different output sources. If you have USB speakers they can have a different card number than 0.
Edit December 2, 2016
For some unknown reason the script was broken today. Above code used to read: "$(cat /sys/class/drm/card0-HDMI-A-1/status" but I had to change card0 to card1 and the code above has been revised as such. I can't explain what changed on my system other than regular Ubuntu updates since November 26, 2016.
Edit December 14, 2016
Above code needed to be switched again back to: "$(cat /sys/class/drm/card0-HDMI-A-1/status". Instead of revising code between card0 and card1 depending on boot, revise program to reference card* to capture both scenarios.
