a weird sound problem appeared after a do-release-upgrade (14.04 -> 16.04): After upgrade, sound output through HDMI/pulseaudio (which used to work just fine before) works erratically: sometimes there's no sound at all even if the pavucontrol panel displays output levels as if everything was ok (if I select/configure HDMI output and play anything with mplayer for instance, it shows the volume level bar bouncing, but no sound from speakers).
sometimes after a reboot, without changing anything to the sound settings, sound is really coming from HDMI output! right now, I can't hear a thing from the HDMI output, but pavucontronl looks like this: pavucontrol screen capture as playing a mp3 file
and here is the output of pacmd list-sinks, as I'm trying to play the same file, no sound actually produced yet...
pacmd list-sinks
1 sink(s) available.
  * index: 15
    driver: <module-alsa-card.c>
    flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
    state: RUNNING
    suspend cause:
    priority: 9950
    volume: front-left: 62850 /  96% / -1,09 dB,   front-right: 62850 /  96% / -1,09 dB
            balance 0,00
    base volume: 65536 / 100% / 0,00 dB
    volume steps: 65537
    muted: no
    current latency: 178,02 ms
    max request: 36 KiB
    max rewind: 64 KiB
    monitor source: 17
    sample spec: s16le 2ch 44100Hz
    channel map: front-left,front-right
                 Stéréo
    used by: 1
    linked by: 1
    configured latency: 210,00 ms; range is 0,50 .. 371,52 ms
    card: 0 <alsa_card.pci-0000_00_03.0>
    module: 2
    properties:
        alsa.resolution_bits = "16"
        device.api = "alsa"
        device.class = "sound"
        alsa.class = "generic"
        alsa.subclass = "generic-mix"
        alsa.name = "HDMI 0"
        alsa.id = "HDMI 0"
        alsa.subdevice = "0"
        alsa.subdevice_name = "subdevice #0"
        alsa.device = "3"
        alsa.card = "0"
        alsa.card_name = "HDA Intel HDMI"
        alsa.long_card_name = "HDA Intel HDMI at 0xaa134000 irq 49"
        alsa.driver_name = "snd_hda_intel"
        device.bus_path = "pci-0000:00:03.0"
        sysfs.path = "/devices/pci0000:00/0000:00:03.0/sound/card0"
        device.bus = "pci"
        device.vendor.id = "8086"
        device.vendor.name = "Intel Corporation"
        device.product.id = "160c"
        device.product.name = "Broadwell-U Audio Controller"
        device.form_factor = "internal"
        device.string = "hdmi:0"
        device.buffering.buffer_size = "65536"
        device.buffering.fragment_size = "32768"
        device.access_mode = "mmap+timer"
        device.profile.name = "hdmi-stereo"
        device.profile.description = "Digital Stereo (HDMI)"
        device.description = "Audio interne Digital Stereo (HDMI)"
        alsa.mixer_name = "Intel Broadwell HDMI"
        alsa.components = "HDA:80862808,80860101,00100000"
        module-udev-detect.discovered = "1"
        device.icon_name = "audio-card-pci"
    ports:
        hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: yes)
            properties:
                device.icon_name = "video-display"
                device.product.name = "PLB2403WS"
    active port: <hdmi-output-0>
I checked the HDMI cable, tried to use another hdmi source on the same hdmi monitor: definitely not a hardware pb. No such trouble using the analogic output so far.
I read this thread and tried to apply the same recipes (speaker-test using hdmi related devices does not produce any sound, works well with analogic (PCH) device) so it doesn't seem to be a default sampling rate pb.
It rather looks like a lower level hdmi module problem, though snd_hda_codec_hdmi is loaded, and I'm stuck there, trying to guess. Any idea is welcome! :-)
