63
I am trying to move the data directory of my MySQL database to a second disk array that I have as a mount point /array2/.
The problem I am having is I have tried everything and after I modify the location of datadir in my.cnf mysql will not start up again.
All I get is:
start: Job failed to start
Jorge Castro
  • 73,717
7 Answers7
66
Forgot about app armour.
For anyone that is interested I did the following to move the folder.
Stop the mysql server:
stop mysql
Create the new directory:
mkdir /array2/mysql
Copy over ONLY the database folders:
cp -R /var/lib/mysql /array2/mysql
cp -R /var/lib/mysql/users /array2/mysql
Backup the my.cnf file:
cp /etc/mysql/my.cnf /root/my.cnf.backup
Edit the my.cnf file:
nano /etc/mysql/my.cnf
Change all mentions of the old datadir and socket to your new location
Mine became:
datadir=/array2/mysql
socket=/array2/mysql/mysql.sock
Update the directory permissions:
chown -R mysql:mysql /array2/mysql
Rename the old directory:
mv /var/lib/mysql /var/lib/mysql-old
Create a symlink, just in case:
ln -s /array2/mysql /var/lib/mysql
Let AppArmor know about the new datadir:
echo "alias /var/lib/mysql/ -> /your/new/datadir/," >> /etc/apparmor.d/tunables/alias
Reload the apparmor profiles
sudo /etc/init.d/apparmor reload
Then start mysql:
start mysql
23
I found that AppArmor was the culprit by examining the syslog, and was able to successfully change the mysql data location by following this process.
Please note that, in files edited below, lines starting with + were added, and lines starting with - were removed. You should not actually type/paste the + signs when adding lines to these files.
I cloned the mysql directory to the new location:
sudo rsync -av /var/lib/mysql /new_dir
Then I edited the datadir line in /etc/mysql/my.cnf:
sudo vi /etc/mysql/my.cnf
-datadir     = /var/lib/mysql
+datadir     = /new_dir/mysql
Then I edited /etc/apparmor.d/usr.sbin.mysqld:
sudo vi /etc/apparmor.d/usr.sbin.mysqld
-  /var/lib/mysql/ r,
-  /var/lib/mysql/** rwk,
+  /new_dir/mysql/ r,
+  /new_dir/mysql/** rwk,
Then I restarted mysql.
Eliah Kagan
  • 119,640
13
Be aware.
If you have InnoDB tables you MUST copy over the ibdata* and ib_logfile* files or you will not be able to use the the tables. You will get:
'Table 'databaseName.tableName' doesn't exist'
errors.
Run this copy command to copy over the ibdata* and ib_logfile* files.
sudo cp -p /var/lib/mysql/ib* /array2/mysql/
BuZZ-dEE
  • 14,533
dave
  • 131
I prefer to use mount with bind option so I avoid any further changes in Apparmor and Mysql configuration.
For example:
Suppose I want to move everything in /var/www. Lets say this dir is my dev environment and it is mounted in a different partition
  1. First we need to stop mysql:
    sudo systemctl stop mysql.service
  2. We move files (preserving permission)
    sudo rsync -av /var/lib/mysql /var/www
    This will generate a directory /var/www/mysql/ with all the content.
  3. We remove everything in the old directory:
    sudo rm -r /var/lib/mysql/*
  4. We mount the new directory with bind option in the old one.
    edit /etc/fstab and add this line:
    /var/www/mysql /var/lib/mysql  none  bind 0 0
    This will mount the /var/www/mysql in our empty dir /var/lib/mysql
    The bind option here do the magic, it will populate /var/lib/mysql with the content of /var/www/mysql so for mysql and apparmor it will be the like nothing has changed.
  5. Now we do the mount:
    sudo mount -a
    and restart mysql.
muru
  • 207,228
Postadelmaga
  • 5,759
I just tried another way, that some may find useful:
copy with permissions intact:
rsync -avzh /var/lib/mysql /path/to/new/place
back up (in case something goes wrong):
mv /var/lib/mysql /var/lib/_mysql
create a new empty directory in place of old:
mkdir /var/lib/mysql
bind mount the new location to the old:
mount -B /path/to/new/place /var/lib/mysql
Hope that helps someone, because symlinking didn't work for me, and this was the simplest way
If you move your datadir, you not only need to give the new datadir permissions, but you need to insure all parent directories have permission.
I moved my datadir to a hard drive, mounted in Ubuntu as:
/media/*user*/Data/
and my datadir was Databases.
I had to set permissions to 771 to each of the media, user and Data directories:
sudo chmod 771 *DIR*
If this does not work, another way you can get mysql to work is to change user in /etc/mysql/my.cnf to root; though there are no doubt some issues with doing that from a security perspective.
You realize if you follow the commands verbatim from the accepted answer it will fail?
Will copy /var/lib/mysql to /array2/mysql/mysql.
When you set your configuration file you better be putting in /array2/mysql/mysql as the directory or else your mysqld will fail to start.
The better copy commands would be:
cp -R /var/lib/mysql /array2/ cp -R /var/lib/mysql/users /array2/mysql
Just my 2 cents worth.
