77
If I click the desktop app of "Steam", nothing happens.
Running steam in terminal produces the following:
STEAM_RUNTIME is enabled automatically
Installing breakpad exception handler for appid(steam)/version(1474415843)
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
What's interesting is that if I change my GPU driver to xorg, it works perfectly.
What can I do to make it work? It stopped working after the latest steam update(36 hours ago).
I tried uninstalling nvidia - sudo apt-get remove nvidia* and re-installing the driver, but with no luck.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
cbll
  • 1,620
6 Answers6
70
Ubuntu 16.04+ For anyone still getting same error, if you are using nvidia driver, sometimes you will see that libGL.so.1 points to ambiguous libGL provided by both mesa and nvidia. To test this, you can run this command
$ sudo ldconfig -p | grep -i gl.so
The output was something like:
    libwayland-egl.so.1 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libwayland-egl.so.1
    libftgl.so.2 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libftgl.so.2
    libcogl.so.20 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libcogl.so.20
    libQt5OpenGL.so.5 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libQt5OpenGL.so.5
    libQtOpenGL.so.4 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libQtOpenGL.so.4
    libQtOpenGL.so.4 (libc6) => /usr/lib/i386-linux-gnu/libQtOpenGL.so.4
    libOpenGL.so.0 (libc6,x86-64) => /usr/lib/nvidia-378/libOpenGL.so.0
    libOpenGL.so (libc6,x86-64) => /usr/lib/nvidia-378/libOpenGL.so
    libGL.so.1 (libc6,x86-64) => /usr/lib/nvidia-378/libGL.so.1
    libGL.so.1 (libc6) => /usr/lib/i386-linux-gnu/mesa/libGL.so.1
    libGL.so.1 (libc6) => /usr/lib32/nvidia-378/libGL.so.1
    libGL.so (libc6,x86-64) => /usr/lib/nvidia-378/libGL.so
    libGL.so (libc6) => /usr/lib32/nvidia-378/libGL.so
    libEGL.so.1 (libc6,x86-64) => /usr/lib/nvidia-378/libEGL.so.1
    libEGL.so.1 (libc6) => /usr/lib32/nvidia-378/libEGL.so.1
    libEGL.so (libc6,x86-64) => /usr/lib/nvidia-378/libEGL.so
    libEGL.so (libc6) => /usr/lib32/nvidia-378/libEGL.so
Now I just needed to remove the library provided by mesa and everything worked perfectly.
$ sudo rm /usr/lib/i386-linux-gnu/mesa/libGL.so.1
Update: This issue no longer exists from Ubuntu 18.04 LTS.
32
In my situation I had to install the i386 NVIDIA drivers. It worked thereafter.
sudo apt install libnvidia-gl-440:i386
Have a great day!
Stan S.
  • 487
17
Windows Subsystem for Linux (WSL) Has Same Error
In Windows Subsystem for Linux (WSL) under Windows 10 there the file /usr/lib/i386-linux-gnu/mesa/libGL.so.1 does not exist. Instead there is the file /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1 seems to replace it. However if you delete the replacement file the library doesn't work at all.
Rename library then rename back solves problem
If you rename the file and then rename it back the errors disappear and it works a lot faster:
rick@alien:/mnt/e/etc$ lock-screen-timer
Linux version 4.4.0-43-Microsoft (Microsoft@Microsoft.com) (gcc version 5.4.0 (GCC) ) #1-Microsoft Wed Dec 31 14:42:53 PST 2014
Gtk-Message: GtkDialog mapped without a transient parent. This is discouraged.
rick@alien:/mnt/e/etc$ sudo ldconfig -p | grep -i gl.so
        libGL.so.1 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1
        libEGL.so.1 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/mesa-egl/libEGL.so.1
rick@alien:/mnt/e/etc$ sudo rm /usr/lib/i386-linux-gnu/mesa/libGL.so.1
rm: cannot remove '/usr/lib/i386-linux-gnu/mesa/libGL.so.1': No such file or directory
rick@alien:/mnt/e/etc$ sudo mv /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1 /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1.ORIGINAL
/usr/bin/zenity: error while loading shared libraries: libGL.so.1: cannot open shared object file: No such file or directory
rick@alien:/mnt/e/etc$ sudo mv /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1.ORIGINAL /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1
I verified the change is persistent, ie close the WSL terminal window and open a new window.
Quick Fix From Comments
In comment below it is suggested to try https://stackoverflow.com/a/63450299/6929343:
export LIBGL_ALWAYS_INDIRECT=1
For a quick test, run:
glxinfo -B | grep renderer
NOTE: I haven't tested this solution.
What's Using the Library?
The library is used by yad in the lock-screen-timer bash script upgraded with hybrid support for WSL in addition to Ubuntu. Yad is a fork of Zenity which is why you see the Zenity-like Gtk-Message: reference in the third error message above.
Here's what the yad window looks like in Ubuntu (in WSL it's slightly different):
Lock Screen Timer
This might be a nvidia driver issue, according to a steam-for-linux issue.
In my case, I installed SuperTuxKart through flapak, when I ran it, I met following errors:
..:: Antarctica Rendering Engine 2.0 ::..
Linux 4.15.0-52-generic #56-Ubuntu SMP Tue Jun 4 22:49:08 UTC 2019 x86_64
My solution is:
  1. Check nvidia driver on my system
ubuntu-drivers devices
It has nvidia-driver-430 installed already.
  1. According to the steam-for-linux issue issue, install nvidia-driver-418 to replace nvidia-driver-430
sudo apt install libnvidia-gl-418
It prompted that it lack dependency of libnvidia-compute-418, so just install libnvidia-compute-418 first.
sudo apt install libnvidia-compute-418
then
  1. Reboot system.
Then I ran SuperTuxKart, it worked.
Yong Yang
  • 111
In my case the issue was that I had enabled some CUDA apt sources that had installed the 440 nvidia driver and tools. Once I disabled that and installed the then latest version of nvidia driver (435), it installed everything else needed and the error went away.
The solutions that worked for me:
  • Ubuntu 20.04:
    (without :i386)
  • WSL2 Windows 10: run XServer with -nowgl (and -ac):
    "C:\Program Files\VcXsrv\vcxsrv.exe" :0 -multiwindow -clipboard -nowgl -ac #see https://askubuntu.com/a/1394781/498339
PJ127
  • 311
