If i have the default nvidia drivers (nvidia-384) steam doesn't start. If I run steam in a terminal i get this:
Running Steam on ubuntu 16.04 64-bit
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
[2018-04-05 09:36:52] Startup - updater built Apr 2 2018 15:23:43
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2018-04-05 09:36:52] Checking for update on startup
[2018-04-05 09:36:52] Checking for available updates...
[2018-04-05 09:36:53] Download skipped: /client/steam_client_ubuntu12 version 1522709999, installed version 1522709999
[2018-04-05 09:36:53] Nothing to do
[2018-04-05 09:36:53] Verifying installation...
[2018-04-05 09:36:53] Performing checksum verification of executable files
[2018-04-05 09:36:54] Verification complete
And close. Nothing more happen.
If I have the "x.org x server - Nouveau" driver it run fine.
I have tried:
sudo apt-get remove steam
sudo apt-get purge steam
sudo rm -rf ~/.local/share/Steam && rm -rf ~/.steam
and then
sudo apr-get install steam
and the problem doesn't fix.
I don't know what to do. Thanks.
UPDATE and FIX
The problem was solved doing this:
sudo ldconfig -p | grep -i gl.so
sudo rm /usr/lib/i386-linux-gnu/mesa/libGL.so.1
I found th solution here.
It looks that this is a common problem with nvidia drivers. Thanks.
