Probably the same problem as Steam: libGL error: No matching fbConfigs or visuals found libGL error: failed to load driver: swrast but none of the solution there works for me.
This happens after I updated my driver, the old and working one probable 384.
I installed the 440 from .run file to use cuda 10 and detectron2, which is worked.
The problem is that I can't run steam anymore, run it via terminal give me this
ILocalize::AddFile() failed to load file "public/steambootstrapper_english.txt".
[2019-11-09 01:36:34] Startup - updater built Nov 23 2016 01:05:42
SteamUpdateUI: An X Error occurred
X Error of failed request:  BadValue (integer parameter out of range for operation)
Previously, if I switch to 384 I can use steam normally but for some reason it suddenly give me a start job is running for hold and I have to re-install the driver to be able to boot my PC properly, now both the apt install and software and update have only 390 and 410. And I can't open steam anymore.
I tried sudo apt install libnvidia-gl but it doesn't work either.
I had the same issue. I disabled my graphics driver and installed it again, and it seemed to work just fin. See https://phoenixnap.com/kb/install-nvidia-drivers-ubuntu
I'm on Ubuntu 20.04 LTS, with Quadro NVIDIA graphics.
Josh
  • 143
