Well I had network manager by Network-Manager. For some reason I have to put the same configuration in /etc/network/interfcaes. Here's result of ifconfig before changes
enp0s17   Link encap:Ethernet  HWaddr 08:00:27:d4:30:fe
          inet addr:10.1.178.177  Bcast:10.1.178.255  Mask:255.255.255.0
          inet6 addr: fe80::b077:68e:9963:1b54/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:7053 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3514 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:8356545 (8.3 MB)  TX bytes:299049 (299.0 KB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:251 errors:0 dropped:0 overruns:0 frame:0
          TX packets:251 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:25485 (25.4 KB)  TX bytes:25485 (25.4 KB)
With the same configuration as reference I created a new file /etc/network/interfaces as
auto lo
iface lo inet loopback
auto enp0s1
iface enp0s1 inet static
address 10.1.178.179
netmask 255.255.255.0
getway 10.1.178.1
I made a small change in the interface-name. In place of enp0s17 I tried using enp0s1 and enp0s17:1(virtual interface is where I am heading).
But, I am not able to take this configuration up. I have done,
First, I did systemctl stop network-manager && systemctl restart networking.
networking.service - Raise network interfaces
   Loaded: loaded (/lib/systemd/system/networking.service; enabled; vendor preset: enabled)
  Drop-In: /run/systemd/generator/networking.service.d
           └─50-insserv.conf-$network.conf
   Active: failed (Result: exit-code) since Wed 2016-10-05 18:17:56 IST; 20min ago
     Docs: man:interfaces(5)
  Process: 15599 ExecStop=/sbin/ifdown -a --read-environment (code=exited, status=0/SUCCESS)
  Process: 16189 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=1/FAILURE)
  Process: 16183 ExecStartPre=/bin/sh -c [ "$CONFIGURE_INTERFACES" != "no" ] && [ -n "$(ifquery --read-environment --list   --exclude=lo)" ] &&
 Main PID: 16189 (code  =exited, status=1/FAILURE)
Oct 05 18:17:56 souvik-VirtualBox systemd[1]: Starting Raise network interfaces...
Oct 05 18:17:56 souvik-VirtualBox ifup[16189]: Cannot find device "enp0s1"
Oct 05 18:17:56 souvik-VirtualBox ifup[16189]: Failed to bring up enp0s1.
Oct 05 18:17:56 souvik-VirtualBox systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
Oct 05 18:17:56 souvik-VirtualBox systemd[1]: Failed to start Raise network interfaces.
Oct 05 18:17:56 souvik-VirtualBox systemd[1]: networking.service: Unit entered failed state.
Oct 05 18:17:56 souvik-VirtualBox systemd[1]: networking.service: Failed with result 'exit-code'.
Furthermore I tried ifdown enp0s17 --force successfully, verified as
$ cat /run/network/ifstate
lo=lo
followed ifup enp0s1 --verbose --force, which results
Configuring interface enp0s1=enp0s1 (inet)
/bin/run-parts --exit-on-error --verbose /etc/network/if-pre-up.d
run-parts: executing /etc/network/if-pre-up.d/ethtool
run-parts: executing /etc/network/if-pre-up.d/wireless-tools
run-parts: executing /etc/network/if-pre-up.d/wpasupplicant
/bin/ip addr add 10.1.178.177/255.255.255.0 broadcast 10.1.178.255    dev enp0s1 label enp0s1
Any help would be appreciated.
UPDATE
After reading through this andThis, my problem scope has reduced. How can resent the network-interface-name assigned by udev like from enp0s17 to enp0s1 or so ?
And, how can I go ahead adding virtual-network-interfaces aka network-alias, because they will be requiring new names as enps01:1 or enp0s1:2 and likewise ?
Additionally I am missing rule files under /etc/udev/rules.d and am not able to regenerate it as well. Somewhat similar to this post.
FURTHERMORE
A network-alias can be added in GUI using Network Manager like this. How can this be done in CLI, becuase in Server is not supposed to have GUI.
soufrk
  • 143
