I recently installed Ubuntu Server 16.04 onto a new hard drive. I had to install it while connected via USB on a different computer (due to the installer not able to detect a keyboard). I attached the hard drive via SATA to the new server. I can now boot and it sees the keyboard.
I however have no network.
I am missing the /etc/udev/rules.d/70-persistent-net.rules file.
When I execute sudo lshw -class network I get the following;
*-network DISABLED
description: Ethernet interface
When I execute ifconfig -a I get the following;
eno1 Link encap:Ethernet HWaddr 9c:5c:8e:95:44:6d
Arronical
  • 20,241
Fosol
  • 61
my copy of that file looks like this :
# file was automatically generated by the /lib/udev/write_net_rules
# program, run by the persistent-net-generator.rules rules file.
# You can modify it, as long as you keep each rule on a single
# line, and change only the value of the NAME= key.
# PCI device 0x10ec:0x8168 (r8169)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="ur::ma:ca:dd:re:ss", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
yours will need adjustment to you mac address and your device but as it says at the top of the file its generated by /lib/udev/write_net_rules
Amias
  • 5,359
sudo udevadm trigger --subsystem-match=net --action=add
will generate /etc/udev/rules.d/70-persistent-net.rules.
Run udevadm trigger --help for more options.
edwinksl
  • 24,109
Rauf
