I am trying to install python-dev on a Ubuntu 16.04 LTS (64 bit) guest running on a Windows host. I tried installing using apt-get and then through aptitude, but I seem to be running into errors.
~$sudo aptitude install python-dev
gives,
The following NEW packages will be installed:
libexpat1-dev{ab} libpython-dev{a} libpython2.7-dev{ab} python-dev python2.7-dev{ab}
0 packages upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 28.2 MB of archives. After unpacking 42.1 MB will be used.
python2.7-dev : Depends: python2.7 (= 2.7.11-7ubuntu1) but 2.7.12-1~16.04 is installed.
Depends: libpython2.7 (= 2.7.11-7ubuntu1) but 2.7.12-1~16.04 is installed.
libexpat1-dev : Depends: libexpat1 (= 2.1.0-7) but 2.1.0-7ubuntu0.16.04.2 is installed.
libpython2.7-dev : Depends: libpython2.7-stdlib (= 2.7.11-7ubuntu1) but 2.7.12-1~16.04 is installed.
open: 20; closed: 1293; defer: 6; conflict: 6 o
The following actions will resolve these dependencies:
Keep the following packages at their current version:
1) libexpat1-dev [Not Installed]
2) libpython-dev [Not Installed]
3) libpython2.7-dev [Not Installed]
4) python-dev [Not Installed]
5) python2.7-dev [Not Installed]
Accept this solution? [Y/n/q/?]
as the output. Whereas,
~$sudo apt-get install python-dev
gives,
Reading package lists... Done
Building dependency tree
python-dev : Depends: libpython-dev (= 2.7.11-1) but it is not going to be installed
Depends: python2.7-dev (>= 2.7.11-1~) but it is not going to be installed
I ran sudo aptitude update and sudo aptitude upgrade, but that doesn't solve the problem.
In addition, I ran the steps given in the following links:
but nothing seems to work.
From aptitude's message, I think the dependencies installed on my system are of a higher version than what are required by the package (e.g., one message saysDepends: libpython2.7 (= 2.7.11-7ubuntu1) but 2.7.12-1~16.04 is installed.).
I am guessing my options are either to,
- uninstall the existing packages (which I'd rather not), or
- add a more updated PPA for Python-stuff.
My current repositories are:
~$egrep -v '^#|^ *$' /etc/apt/sources.list /etc/apt/sources.list.d/*
/etc/apt/sources.list:deb http://us.archive.ubuntu.com/ubuntu/ xenial main restricted
/etc/apt/sources.list:deb http://us.archive.ubuntu.com/ubuntu/ xenial universe
/etc/apt/sources.list:deb http://us.archive.ubuntu.com/ubuntu/ xenial multiverse
Any ideas how I can install python-dev?
Thanks in advance!
