Ubuntu 14.04.3. I can't install python-dev:
yura@ubuntu:~$ sudo apt-get install python-dev
Reading package lists... Done
Building dependency tree
 python-dev : Depends: libpython-dev (= 2.7.5-5ubuntu3) but it is not going to be installed
              Depends: python2.7-dev (>= 2.7.5-1~) but it is not going to be installed
Also:
yura@ubuntu:~$ sudo apt-get install libpython-dev
[sudo] password for yura:
 libpython-dev : Depends: libpython2.7-dev (>= 2.7.5-1~) but it is not going to be installed
yura@ubuntu:~$ sudo apt-get install libpython2.7-dev
 libpython2.7-dev : Depends: libpython2.7-stdlib (= 2.7.6-8) but 2.7.6-8ubuntu0.2 is to be installed
                    Depends: libpython2.7 (= 2.7.6-8) but 2.7.6-8ubuntu0.2 is to be installed
yura@ubuntu:~$ sudo apt-get install libpython2.7-stdlib
libpython2.7-stdlib is already the newest version.
libpython2.7-stdlib set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
I have tried this commands, they does not help:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get autoremove
auso apt-get install -f
When I trying to execute apt-get update, I receive this:
yura@ubuntu:~$ sudo apt-get update
Ign http://us.archive.ubuntu.com trusty InRelease
Get:1 http://us.archive.ubuntu.com precise-updates InRelease [55,7 kB]
Get:2 http://us.archive.ubuntu.com trusty Release.gpg [933 B]
Get:3 http://us.archive.ubuntu.com precise-updates/main i386 Packages [1 045 kB]
Ign http://dl.google.com stable InRelease
Ign http://extras.ubuntu.com trusty InRelease
Get:4 http://dl.google.com stable Release.gpg [181 B]
Get:5 http://extras.ubuntu.com trusty Release.gpg [72 B]
Get:6 http://dl.google.com stable Release [1 189 B]
Get:7 http://extras.ubuntu.com trusty Release [11,9 kB]
Get:8 http://dl.google.com stable/main amd64 Packages [1 363 B]
Get:9 http://extras.ubuntu.com trusty/main Sources [14 B]
Get:10 http://extras.ubuntu.com trusty/main i386 Packages [14 B]
Ign http://dl.google.com stable/main Translation-en_US
Ign http://extras.ubuntu.com trusty/main Translation-en_US
Get:11 http://us.archive.ubuntu.com precise-updates/restricted i386 Packages [16,1 kB]
Get:12 http://us.archive.ubuntu.com precise-updates/main Translation-en [414 kB]
Get:13 http://us.archive.ubuntu.com precise-updates/restricted Translation-en [3 869 B]
Get:14 http://us.archive.ubuntu.com trusty Release [58,5 kB]
Get:15 http://us.archive.ubuntu.com trusty/main Sources [1 064 kB]
Get:16 http://us.archive.ubuntu.com trusty/restricted Sources [5 433 B]
Get:17 http://us.archive.ubuntu.com trusty/universe Sources [6 399 kB]
Get:18 http://us.archive.ubuntu.com trusty/multiverse Sources [174 kB]
Get:19 http://us.archive.ubuntu.com trusty/main i386 Packages [1 348 kB]
Get:20 http://us.archive.ubuntu.com trusty/restricted i386 Packages [13,4 kB]
Get:21 http://us.archive.ubuntu.com trusty/universe i386 Packages [5 866 kB]
Get:22 http://us.archive.ubuntu.com trusty/multiverse i386 Packages [134 kB]
Get:23 http://us.archive.ubuntu.com trusty/main Translation-en [762 kB]
Get:24 http://us.archive.ubuntu.com trusty/multiverse Translation-en [102 kB]
Get:25 http://us.archive.ubuntu.com trusty/restricted Translation-en [3 457 B]
Get:26 http://us.archive.ubuntu.com trusty/universe Translation-en [4 089 kB]
Ign http://us.archive.ubuntu.com trusty/main Translation-en_US
Ign http://us.archive.ubuntu.com trusty/multiverse Translation-en_US
Ign http://us.archive.ubuntu.com trusty/restricted Translation-en_US
Ign http://us.archive.ubuntu.com trusty/universe Translation-en_US
Fetched 21,6 MB in 1min 7s (318 kB/s)
W: Duplicate sources.list entry http://us.archive.ubuntu.com/ubuntu/ precise-updates/main i386 Packages (/var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_precise-updates_main_binary-i386_Packages)
W: Duplicate sources.list entry http://us.archive.ubuntu.com/ubuntu/ precise-updates/restricted i386 Packages (/var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_precise-updates_restricted_binary-i386_Packages)
W: You may want to run apt-get update to correct these problems
I have common python2.7 installed, but I also need python-dev.
Also I have tried this from the related question (does not work for me):
echo "deb http://us.archive.ubuntu.com/ubuntu/ precise-updates main restricted" | sudo tee -a /etc/apt/sources.list.d/precise-updates.list
sudo apt-get update
sudo apt-get install python2.7-dev
Here is the output of this commands:
apt-cache policy python2.7-dev
apt-cache show python2.7
Gooman
  • 71
I have found the desicion using packages.ubuntu.com site.
  1. Edit file /etc/apt/sources.list (double click in your file manager or use sudo nano /etc/apt/sources.list from terminal) . Add new record to the list of packages:
    deb http://cz.archive.ubuntu.com/ubuntu wily main
  2. Close this file (Ubuntu will automatically update your packages). If it's not, then execute sudo apt-get update.
  3. Execute sudo apt-get install python-dev. It should work. If it does not, then try another packages links from here.
user8292439
  • 3,878
  • 32
  • 57
Gooman
  • 71
This means that you're mentioning deb http://us.archive.ubuntu.com/ubuntu precise-updates main and deb http://us.archive.ubuntu.com/ubuntu precise-updates restricted twice somewhere.
  1. Make sure that there's no mention of precise-updates in /etc/apt/sources.list. If there is copy it, remove it, and attempt another sudo apt-update && sudo apt-upgrade -y.
  2. Move to /etc/apt/sources.list.d. Check each file for a mention of precise-updates and remove the entire line on the first file you find. From this point you should be able to run sudo apt-update && sudo apt-upgrade -y successfully. If you can't, there's another duplicate somewhere in this directory and you need to run Step 2 again.
Matt O.
  • 543
