19
I am using gnome-shell in Ubuntu 11.10. I am getting annoyed when dash search lists Recent Items. I have tried many ways to prevent it like
  • Deleting activity.sqlite and activity.sqlite-journal files under ~/.local/share/zeitgeist
  • Adding all the possible entries in Activity Log Manager to prevent application logging
  • Specifying time range in Activity Log Manager to forget my activities.
But none of the methods are working. The recent items list is still populated.
Is there any way to tell dash not to list Recent Items while searching, other than the above methods? Or is there any way to delete the recent items list?
pomsky
  • 70,557
Vivek
  • 3,829
5 Answers5
20
Gnome-shell uses recently-used and not Zeitgeist to display your recent items.
to disable it follow theses steps:
delete recently-used.xbel:
rm ~/.local/share/recently-used.xbel
create a new empty file:
touch ~/.local/share/recently-used.xbel
make sure the new file cannot be modified:
sudo chattr +i ~/.local/share/recently-used.xbel
now, your display of recent items is gone.
If you want to revert back, remove the i attribute of recently-used.xbel:
sudo chattr -i ~/.local/share/recently-used.xbel
all credits to : http://knezevblog.blogspot.com/2010/05/how-to-ubuntu-clear-and-disable-recent.html
martin
  • 1,809
  • 13
There's also an extension Remove recent items search provider for removing the Recent Items provider now, as well.
A.B.
  • 92,125
guff
Install " Activity Log Manager" using Synaptic and choose apps whose logs you wana see and whose not.
Another approach is here:
$ cat ~/.gtkrc-2.0
gtk-recent-files-max-age=0
$ cat ~/.config/gtk-3.0/settings.ini
[Settings]
Bruno Pereira
  • 74,715
-2
use cairo dock to delete your recent history... instal cairo dock first,,and then run it,, right click on recent-events,,,then choose "Delete today's events" or "Delete all events" I hope it can help
