I saw this post: Prevent gnome-shell's dash from listing Recent Items and I'm not able to remove the recently.used.xbel file.
Do I need to be root to do this?
-rw------- 1 ryan ryan 39157 2012-02-19 15:47 /home/ryan/.local/share/recently-used.xbel --
When I run
rm ~/.local/share/recently-used.xbel
I get
rm: cannot remove `/home/ryan/.local/share/recently-used.xbel': Operation not permitted
Running the same command with sudo returns the same error, and running nautilus as root also returns a similar error.
rylhunt
  • 81
what infinity said. Try ´sudo chattr -i ~/.local/share/recently-used.xbel´, and then try to delete the file again.
– @severin
This did the trick. Thanks
rylhunt
  • 81
~/.local/share/recently-used.xbel is in your home directory and belongs to your current user, so in short I can say: no, you don't need to be root to delete it.
But you need to be more specific about your problem.
GalmWing
  • 380
You could just do a
gksudo nautilus
or which filemanager you are using and simply browse to the file and delete it.
jokerdino
  • 41,732
Try running: lsof |grep recently-used.xbel
This should show if some process has a lock on that file.
You can also try: rm -f ~/.local/share/recently-used.xbel
Jorge Castro
  • 73,717
mhall119
  • 5,037
