There seems to be a lot of problems with installing Spotify in 16.04. I tried this guide here to make sure I wasn't just screwing up, but it never worked. Turns out, this question is a little out-dated. To help out new users, I'll ask the question, give some information, then answer this.
I'm trying to install spotify in Ubuntu 16.04. I tried a few different guides. Here's the steps I've done in the previously mentioned guide. First, I pasted in
echo 'deb http://repository.spotify.com stable non-free' | sudo tee --append /etc/apt/sources.list
Then I added the key using:
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 94558F59
Finally I updated and tried installing Spotify using
sudo apt-get update && sudo apt-get install spotify-client
James
  • 311
Spotify is now available as a snap so you can find it in Ubuntu Software, or install in a terminal with one command:-
snap install spotify
popey
  • 24,549
And the answer is super simple! Everything in what you did was right except for the key you added! Replace
with
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys BBEBDCB318AD50EC6865090613B00F1FD2C19886
and follow the rest of the steps the same! If you need all the updated steps, you can find them here
James
  • 311
Using the key in the command sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys BBEBDCB318AD50EC6865090613B00F1FD2C19886 I got the following warning when installing spotify-client:
"WARNING: The following packages cannot be authenticated!"
www.spotify.com/us/download/linux gives the following code to use for the key: sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 0DF731E45CE24F27EEEB1450EFDC8610341D9410
This worked and allowed a successful install of spotify-client without any warnings, when following the other steps in the original question. Running Ubuntu 16.04 64-bit.
