11
Hi everyone I'm attempting to install spotify, I've been running linux for less than 24 hours so please cut me some slack if this seems trivial. Here is a link to the webpage https://www.spotify.com/us/download/previews/ and the example script.
  1. Add this line to your list of repositories by editing your /etc/apt/sources.list
    deb http://repository.spotify.com stable non-free
  2. If you want to verify the downloaded packages, you will need to add our public key
    sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 94558F59
  3. Run apt-get update
    sudo apt-get update
  4. Install spotify!
    sudo apt-get install spotify-client
would someone be nice enough to walk me through this? I'm not even sure where to start.
guntbert
  • 13,475
Open your favorite terminal, or just any.
ctrl + alt +t should open the default terminal, if not, search for terminal in the application menu.
Paste in
echo 'deb http://repository.spotify.com stable non-free' | sudo tee --append /etc/apt/sources.list
It will ask for your user password, just type it in (you can't see the characters, but it's there, just type and press enter when done.)
Then paste
And then, guess what, paste in (we'll combine the two last commands here)
sudo apt-get update && sudo apt-get install spotify-client
You can paste in the terminal with ctrl + shift + v, right click or by right clicking and selecting paste, depending on the terminal.
If you're running 15.04, running spotify-client will probably cause whining about missing dependencies, here's a link about that.
If the link goes dead, I've included the basic stuff from that below.
Download if your system is 32-bit
Download if your system is 64-bit
Then navigate to where ever you downloaded said files, and run
sudo dpkg -i libcrypt11*
And you should be up and running before you can say streichholzschächtelchen.
Christian
  • 275
Spotify is now available as a snap so you can find it in Ubuntu Software, or install in a terminal with one command:-
snap install spotify
popey
  • 24,549
Open terminal using ctrl + alt + t. Type (or paste) in
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys BBEBDCB318AD50EC6865090613B00F1FD2C19
Next, type:
echo deb http://repository.spotify.com stable non-free | sudo tee /etc/apt/sources.list.d/spotify.list
Finally just type
sudo apt-get update && sudo apt-get install spotify-client.
This does work in 16.04. Previous version only worked 15.10 and earlier.
James
  • 311
