There are various ways to clone a machine. Make an image, and restore the image on other hardware. However, if you want to move your server to new hardware, with very little downtime (within some minutes), you can use the description in this article. The article assumes a Debian Linux system, but this will work with Ubuntu as well.
Install a base system
You will need a couple of things before you can start hotcloning:
a running minimal install (should take you max. 10 minutes)
a running network card
disks and partitions mounted the way you want them
ssh and rsync installed
No other running services (except for sshd, if you do this remote like in the example). stop inetd, atd, crond, klogd, syslogd
Synchronize the data
Using rsync we can synchronize old_machine to new_machine. Rsync only transfers differences, so you can stop and restart rsync any time, and you can also resync several days later without starting all over again, or rerun rsync to transfer all changed files.
Exclude patterns for rsync
Some files should not be transferred because they are hardware specific, or are available by default, or auto-generated.
These are specific for your hardware and your partition setup:
/boot/
/lib/modules
/etc/modules
/etc/lilo.conf
/etc/fstab
/etc/mtab
These are already available. /proc is a virtual filesystem provided by the running kernel, /dev is the device tree from the base install, lost+found are directories created during partition formatting:
/proc
/dev
lost+found/
These are excluded because you want to keep the logs separate for each machine, and you want (for now) to have a different network setup for each machine:
/var/log
/etc/network/interfaces
An exclude file contains all these entries, every entry on a new line. If this isn't clear see man rsync
Here's an example hotclone_exclude file which you'll store in the /root directory and reference with the rsync command:
/boot/
/lib/modules
/etc/modules
/etc/lilo.conf
/etc/fstab
/etc/mtab
/proc
/dev
lost+found/
/var/log
/root
Warning: if you have network mounts you need to add them to the exclude file too!!!
Sync data
rsync -e ssh -avz --exclude-from=/root/hotclone_exclude old_server:/ /
Switch servers!
stop services on old_server
rerun rsync (should not take long since most transfers are done already)
update /etc/network/interfaces on new_server to contain the IP address of the old_server
run ifdown -a on old_server
run ifdown -a on new_server
run ifup -a on new_server
Put the old server aside unchanged as a spare (better safe than sorry).
You should be all set.
Further note:
If you need to exclude the files from a specific package you can obtain them with apt-file as in apt-file packagename which will give you a list of files in that package and their installation locations.
Example:
$apt-file list trash-cli
trash-cli: /usr/bin/restore-trash
trash-cli: /usr/bin/trash
trash-cli: /usr/bin/trash-empty
trash-cli: /usr/bin/trash-list
trash-cli: /usr/bin/trash-put
trash-cli: /usr/lib/python2.7/dist-packages/integration_tests/__init__.py
trash-cli: /usr/lib/python2.7/dist-packages/integration_tests/assert_equals_with_unidiff.py
trash-cli: /usr/lib/python2.7/dist-packages/integration_tests/describe_trash_list.py
trash-cli: /usr/lib/python2.7/dist-packages/integration_tests/files.py
trash-cli: /usr/lib/python2.7/dist-packages/integration_tests/output_collector.py
trash-cli: /usr/lib/python2.7/dist-packages/integration_tests/test_file_descriptions.py
trash-cli: /usr/lib/python2.7/dist-packages/integration_tests/test_filesystem.py
trash-cli: /usr/lib/python2.7/dist-packages/integration_tests/test_persist.py
trash-cli: /usr/lib/python2.7/dist-packages/integration_tests/test_restore_trash.py
trash-cli: /usr/lib/python2.7/dist-packages/integration_tests/test_trash_empty.py
trash-cli: /usr/lib/python2.7/dist-packages/integration_tests/test_trash_put.py
trash-cli: /usr/lib/python2.7/dist-packages/integration_tests/trashinfo.py
trash-cli: /usr/lib/python2.7/dist-packages/trash_cli-0.12.7.egg-info/PKG-INFO
trash-cli: /usr/lib/python2.7/dist-packages/trash_cli-0.12.7.egg-info/SOURCES.txt
trash-cli: /usr/lib/python2.7/dist-packages/trash_cli-0.12.7.egg-info/dependency_links.txt
trash-cli: /usr/lib/python2.7/dist-packages/trash_cli-0.12.7.egg-info/entry_points.txt
trash-cli: /usr/lib/python2.7/dist-packages/trash_cli-0.12.7.egg-info/top_level.txt
trash-cli: /usr/lib/python2.7/dist-packages/trashcli/__init__.py
trash-cli: /usr/lib/python2.7/dist-packages/trashcli/cmds.py
trash-cli: /usr/lib/python2.7/dist-packages/trashcli/list_mount_points.py
trash-cli: /usr/lib/python2.7/dist-packages/trashcli/trash.py
trash-cli: /usr/lib/python2.7/dist-packages/unit_tests/test_available_trash_dirs.py
trash-cli: /usr/lib/python2.7/dist-packages/unit_tests/test_characterization.py
trash-cli: /usr/lib/python2.7/dist-packages/unit_tests/test_joining_paths.py
trash-cli: /usr/lib/python2.7/dist-packages/unit_tests/test_list_mount_points.py
trash-cli: /usr/lib/python2.7/dist-packages/unit_tests/test_parser.py
trash-cli: /usr/lib/python2.7/dist-packages/unit_tests/test_parsing_trashinfo_contents.py
trash-cli: /usr/lib/python2.7/dist-packages/unit_tests/test_trash.py
trash-cli: /usr/lib/python2.7/dist-packages/unit_tests/test_trash_new_tests.py
trash-cli: /usr/lib/python2.7/dist-packages/unit_tests/test_trash_put.py
trash-cli: /usr/lib/python2.7/dist-packages/unit_tests/test_trashdir.py
trash-cli: /usr/share/doc/trash-cli/changelog.Debian.gz
trash-cli: /usr/share/doc/trash-cli/copyright
trash-cli: /usr/share/man/man1/restore-trash.1.gz
trash-cli: /usr/share/man/man1/trash-empty.1.gz
trash-cli: /usr/share/man/man1/trash-list.1.gz
trash-cli: /usr/share/man/man1/trash-put.1.gz
trash-cli: /usr/share/man/man1/trash.1.gz
trash-cli: /usr/share/pyshared/integration_tests/__init__.py
trash-cli: /usr/share/pyshared/integration_tests/assert_equals_with_unidiff.py
trash-cli: /usr/share/pyshared/integration_tests/describe_trash_list.py
trash-cli: /usr/share/pyshared/integration_tests/files.py
trash-cli: /usr/share/pyshared/integration_tests/output_collector.py
trash-cli: /usr/share/pyshared/integration_tests/test_file_descriptions.py
trash-cli: /usr/share/pyshared/integration_tests/test_filesystem.py
trash-cli: /usr/share/pyshared/integration_tests/test_persist.py
trash-cli: /usr/share/pyshared/integration_tests/test_restore_trash.py
trash-cli: /usr/share/pyshared/integration_tests/test_trash_empty.py
trash-cli: /usr/share/pyshared/integration_tests/test_trash_put.py
trash-cli: /usr/share/pyshared/integration_tests/trashinfo.py
trash-cli: /usr/share/pyshared/trash_cli-0.12.7.egg-info/PKG-INFO
trash-cli: /usr/share/pyshared/trash_cli-0.12.7.egg-info/SOURCES.txt
trash-cli: /usr/share/pyshared/trash_cli-0.12.7.egg-info/dependency_links.txt
trash-cli: /usr/share/pyshared/trash_cli-0.12.7.egg-info/entry_points.txt
trash-cli: /usr/share/pyshared/trash_cli-0.12.7.egg-info/top_level.txt
trash-cli: /usr/share/pyshared/trashcli/__init__.py
trash-cli: /usr/share/pyshared/trashcli/cmds.py
trash-cli: /usr/share/pyshared/trashcli/list_mount_points.py
trash-cli: /usr/share/pyshared/trashcli/trash.py
trash-cli: /usr/share/pyshared/unit_tests/test_available_trash_dirs.py
trash-cli: /usr/share/pyshared/unit_tests/test_characterization.py
trash-cli: /usr/share/pyshared/unit_tests/test_joining_paths.py
trash-cli: /usr/share/pyshared/unit_tests/test_list_mount_points.py
trash-cli: /usr/share/pyshared/unit_tests/test_parser.py
trash-cli: /usr/share/pyshared/unit_tests/test_parsing_trashinfo_contents.py
trash-cli: /usr/share/pyshared/unit_tests/test_trash.py
trash-cli: /usr/share/pyshared/unit_tests/test_trash_new_tests.py
trash-cli: /usr/share/pyshared/unit_tests/test_trash_put.py
trash-cli: /usr/share/pyshared/unit_tests/test_trashdir.py
If you don't have it you can install it with sudo apt install apt-file
For some more useful tools see @drysdam answer here and @Ressu answer here
Sources:
http://olivier.sessink.nl/publications/hotcloning/
http://olivier.sessink.nl/publications/hotcloning/exclude.txt
man rsync
https://superuser.com/questions/82923/how-to-list-files-of-a-debian-package-without-install
