I'm using ubuntu 16.04 LTS and installed plasma desktop using the following command:
sudo apt-get install plasma-desktop
But later I uninstalled it using these commands:
sudo apt-get purge plasma-desktop
sudo apt-get autoremove
After restarting my system, the login screen still gives me an option to choose Ubuntu(default) or Plasma. I want to remove plasma completely.
Anwar
  • 77,855
Uninstalling packages that are installed as dependencies of a metapackage is often harder. Because, autoremove doesn't remove the packages pulled by a metapackage - See this question for an explanation of why Why removing gnome-core does not remove all of it's dependencies?
However, removing this curated list of packages will get rid of plasma desktop mostly, if not completely.
sudo apt --purge autoremove plasma-desktop-data plasma-workspace kded5 libkf5plasma5 libkf5runner5 kactivities
It should not remove other KDE5 applications (as far I can check), but it does remove, you need to install that package later manually.
Anwar
  • 77,855
I'd also like to add on Anwar's answer by saying, also run sudo apt purge kwalletmanager.
It's a program that showed up after I installed KDE Plasma, if you do not need it you can uninstall it.
Simon Sudler
  • 4,111
