I have Ubuntu 16.04 and installed plasma kde environment. later found it had some bugs and tried to uninstall it. apt-get purge kubuntu-desktop works but my grub loader is not changing back to previous version. And it still shows switching option in the login screen for plasma.
I need help. to roll back to original Ubuntu build. I have over 20GB of opt content and have only one partition.
Anwar
  • 77,855
syam
  • 51
To go back to previous grub background
If you want to go back to the Ubuntu's login screen and grub background, use this command
sudo update-alternatives --config text.plymouth
This will show you options to select something like below -
There are 5 choices for the alternative text.plymouth (providing /usr/share/plymouth/themes/text.plymouth).
Selection Path Priority Status
  • 0 /usr/share/plymouth/themes/xubuntu-text/xubuntu-text.plymouth 150 auto mode 1 /usr/share/plymouth/themes/kubuntu-text/kubuntu-text.plymouth 60 manual mode 2 /usr/share/plymouth/themes/text/text.plymouth 40 manual mode 3 /usr/share/plymouth/themes/ubuntu-mate-text/ubuntu-mate-text.plymouth 100 manual mode 4 /usr/share/plymouth/themes/ubuntu-text/ubuntu-text.plymouth 50 manual mode 5 /usr/share/plymouth/themes/xubuntu-text/xubuntu-text.plymouth 150 manual mode
Select the one with Ubuntu by typing the number and press Enter.
To remove most of the KDE and plasma components
Use the solution I gave in this question https://askubuntu.com/a/814627/61218
Anwar
  • 77,855
