10
When I access Apache web server using localhost from same web server PC, it shows Apache2 Ubuntu default page.
But when I access Apache web server using 192.168.0.2, it is giving 403 Forbidden error (Forbidden You don't have permission to access / on this server).
Web Server details
  • Ubuntu 14.04 LTS
  • Apache version 2.4.7
Ownership Commands
www-data sudo adduser ftpuser www-data
sudo chown -R www-data:ftpuser /var/www
sudo chmod -R g+rwX /var/www
In etc/apache2/apache2.conf file
ServerName 192.168.0.2
<Directory/>
    AllowOverride All
    Require all granted
</Directory>
In etc/apache2/port.conf file
NameVirtualHost *:80
Listen *:80
Virtual Host for one website
<VirtualHost *:80>
    ServerName mysite
    DocumentRoot /var/www/mysite
    <Directory /var/www/mysite>
        Options None FollowSymLinks
        AllowOverride None
        Require all granted
    </Directory>
</VirtualHost>
What settings do I need to do at which place? Please help...
K Ahir
  • 242
1. You should configure your /etc/hosts file like that:
127.0.0.1   localhost
127.0.0.1   test-site
127.0.1.1   my-hostname
# The following lines are desirable for IPv6 capable hosts. etc...
Where test-site is the second "localhost". And my-hostname is the "System hostname" defined in /etc/hostname.
2. You should define and enable a Virtual Host (VH):
There is a default HTTP VH. It's placed in /etc/apache2/sites-available/. The filename is 000-default.conf. You have to edit it (you can rename it, if you want, or make some other .conf files, based on it) and after that you have to enable it.
You can enable it manually through creation of "soft, symbolic link":
sudo ln -s /etc/apache2/sites-available/000-default.conf /etc/apache2/sites-enabled/
Or you can use Apache2 tool called a2ensite, which make the same:
sudo a2ensite 000-default.conf
Let's assume there has 3 Virtual Hosts, enabled SSL, and registered private domain (SOS.info for an example):
/etc/apache2/sites-available/http.SOS.info.conf
/etc/apache2/sites-available/https.SOS.info.conf
And one which is created for the purposes of this topic:
/etc/apache2/sites-available/http.test-site.conf
The content of First 2 VHs is:
$ cat /etc/apache2/sites-available/http.SOS.info.conf
<VirtualHost *:80>
    ServerName SOS.info
    ServerAlias www.SOS.info
    ServerAdmin admin@SOS.info
    # Redirect Requests to SSL
    Redirect permanent "/" "https://SOS.info/"
    ErrorLog ${APACHE_LOG_DIR}/http.SOS.info.error.log
    CustomLog ${APACHE_LOG_DIR}/http.SOS.info.access.log combined
</VirtualHost>
This one redirects all HTTP requests to HTTPS.
$ cat /etc/apache2/sites-available/https.SOS.info.conf
<IfModule mod_ssl.c>
    <VirtualHost _default_:443>
        ServerName SOS.info
        DocumentRoot /var/www/html
        SSLEngine on
        SSLCertificateFile /etc/ssl/certs/SOS.info.crt
        SSLCertificateKeyFile /etc/ssl/private/SOS.info.key
        SSLCertificateChainFile /etc/ssl/certs/SOS.info.root-bundle.crt
        #etc..
    </VirtualHost>
</IfModule>
This is the HTTPS VH.
The content of these two files can be posted in one file, but in this case their management (a2ensite/a2dissite)will be more difficult.
The third Virtual Host is that, which is created for our purposes:
$ cat /etc/apache2/sites-available/http.test-site.conf
<VirtualHost *:80>
    ServerName test-site
    ServerAlias test-site.SOS.info
    DocumentRoot /var/www/test-site
    DirectoryIndex index.html
    ErrorLog ${APACHE_LOG_DIR}/test-site.error.log
    CustomLog ${APACHE_LOG_DIR}/test-site.access.log combined
    <Directory /var/www/test-site>
        # Allow .htaccess
        AllowOverride All
        Allow from All
    </Directory>
</VirtualHost>
3. With this configuration you should access:
http://localhost     # pointed to the directory of the mine Domain
https://localhost    # iin our case: /var/www/html (SOS.info), but you should get an error, because the SSL certificate
http://SOS.info      # which redirects to https://SOS.info
https://SOS.info     # you should have valid SSL certificate
http://www.SOS.info  # which is allied to http://SOS.info and redirects to https://SOS.info
https://www.SOS.info # which is allied to https://SOS.info
On the main example you should access and:
http://test-site           # pointed to the directory /var/www/test-site
http://test-site.SOS.info  # which is allied to http://test-site
Try to open the site in the web browser or just try (in the terminal) with next commands:
$ curl -L http://test-site/index.html
$ curl -L http://test-site.SOS.info/index.html
Of course, you need to have some index.html pages in their DocumentRoot :)
I will leave next notes by reason of pedantry :)
4. You need properly configured `/etc/apache2/apache2.conf`.
Ii is good idea to spend some time to improve your server's security. These manuals are about the security configuration: 1st and 2nd. Here you can get free SSL certificate. These sites will help you to check your progress: 1st and 2nd.
According to above security manuals /etc/apache2/apache2.conf file must looks like:
Mutex file:${APACHE_LOCK_DIR} default
PidFile ${APACHE_PID_FILE}
Timeout 60
#KeepAlive Off
KeepAlive On
MaxKeepAliveRequests 100
KeepAliveTimeout 5
HostnameLookups Off
ErrorLog ${APACHE_LOG_DIR}/error.log
LogLevel warn
IncludeOptional mods-enabled/*.load
IncludeOptional mods-enabled/*.conf
Include ports.conf
<Directory />
    AllowOverride None
    Require all denied
</Directory>
<Directory /var/www/>
    AllowOverride None
    Require all granted
</Directory>
AccessFileName .htaccess
<FilesMatch "^\.ht">
    Require all denied
</FilesMatch>
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %O" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
IncludeOptional conf-enabled/*.conf
IncludeOptional sites-enabled/*.conf
# Hide Server type in the http error-pages
ServerSignature Off
ServerTokens Prod
# Etag allows remote attackers to obtain sensitive information
FileETag None
# Disable Trace HTTP Request
TraceEnable off
# Set cookie with HttpOnly and Secure flag.
# a2enmod headers
Header edit Set-Cookie ^(.*)$ $1;HttpOnly;Secure
# Clickjacking Attack
Header always append X-Frame-Options SAMEORIGIN
# CX-XSS Protection
Header set X-XSS-Protection "1; mode=block"
# Disable HTTP 1.0 Protocol
RewriteEngine On
RewriteCond %{THE_REQUEST} !HTTP/1.1$
RewriteRule .* - [F]
# Change the server banner @ ModSecurity
# Send full server signature so ModSecurity can alter it
ServerTokens Full
# Alter the web server signature sent by Apache
<IfModule security2_module>
    SecServerSignature "Apache 1.3.26"
</IfModule>
Header set Server "Apache 1.3.26"
Header unset X-Powered-By
# Hde TCP Timestamp
#   gksu gedit /etc/sysctl.conf
#   >> net.ipv4.tcp_timestamps = 0
# Test: sudo hping3 SOS.info -p 443 -S --tcp-timestamp -c 1
# Disable -SSLv2 -SSLv3 and weak Ciphers
SSLProtocol all -SSLv2 -SSLv3
SSLHonorCipherOrder on
SSLCipherSuite "EECDH+ECDSA+AESGCM EECDH+aRSA+AESGCM EECDH+ECDSA+SHA384 EECDH+ECDSA+SHA256 EECDH+aRSA+SHA384 EECDH+aRSA+SHA256 EECDH+aRSA EECDH EDH+aRSA !aNULL !eNULL !LOW !3DES !MD5 !EXP !PSK !SRP !DSS !RC4"
5. Set up the Firewall.
To allow/deny external access to your web server you can use UFW (Uncomplicated Firewall):
sudo ufw allow http
sudo ufw allow https
To allow only tcp protocol use:
sudo ufw allow http/tcp
sudo ufw allow https/tcp
You can use and the port number directly:
sudo ufw allow 80/tcp
sudo ufw allow 443/tcp
Just in case you can reload the "rules table":
sudo ufw reload
You can use and UFW's GUI interface, called gufw.
sudo apt update
sudo apt install gufw
gufw &
Choice the Office profile. It will set: Status:ON, Incoming:Deny and Outgoing:Allow and add your rules.
6. If you have a router don't forget to forward some ports:
If you have a router and you want your web server to be accessible from Internet, don’t forget to add some port forwarding. Something like this.
pa4080
  • 30,621
Please change the ownership of the directory where you're serving your files from using command:
sudo chown -R www-data:www:data <directory_where_you_serve_files_from>
I am supposed to link you to this answer where solved my problem.
First of all, add permissions to the folder:
sudo chmod -R 775 /var/www
Then add this text:
<Directory /var/www/html>
  AllowOverride All
</Directory>
To the end of this file:
Check the user of the root directory
ls -l ~/projects/
drwxrwxr-x 2 sapama sapama 4096 May 24 07:43 web
The username in this case is sapama
Edit the user and group of that directory in the gedit /etc/apache2/envvars
#export APACHE_RUN_USER=www-data
#export APACHE_RUN_GROUP=www-data
export APACHE_RUN_USER=sapama
export APACHE_RUN_GROUP=sapama
Restart Apache sudo service apache2 restart
Edwin M
  • 101
