How can I check dependency list for a deb package. I am running Ubuntu 11.10 and I have backed up all deb packages from var/cache/apt/archives. I want to format my pc and re-install selected applications only. Also how can I get the list of installed packages and dependencies.
- 6,011
- 5,936
- 10
- 37
- 43
In addition to the dpkg method, you can check the dependencies of packages in the repository:
apt-cache depends package-name
EDIT Updated with @Tino's recommendation. @Tigran's comment no longer applies.
depends VS rdepends
apt-cache
dependspackage-name
//show package-name depends on whoapt-cache
rdependspackage-name
//show who depends on package-name
depends
$ apt-cache depends vim-runtime
vim-runtime
Breaks: vim-tiny
|Recommends: vim
vim-athena
vim-gtk
vim-gtk3
vim-nox
|Recommends: vim-gtk
|Recommends: vim-gtk3
|Recommends: vim-athena
|Recommends: vim-nox
Recommends: vim-tiny
Enhances: vim-tiny
rdepends
$ apt-cache rdepends vim-runtime
vim-runtime
Reverse Depends:
vim
vim
vim-nox
vim-gtk
vim-athena
vim-gtk3
vim
vim-nox
vim-gtk
vim-athena
vim-gtk3
For 14.04 and later:
dpkg doesn't have the -I any more and you have to use dpkg-deb to show package information including dependencies:
dpkg-deb -I package.deb
- 99
I know this question is very old, but it is possible. I also had to dig through StackOverflow/AskUbuntu for ALL of this.
This ONLY SHOWS what depends are in the first package. Not all.
There might be some duplicates in the script methods but you can probably filter them out by doing this:
COMMAND | tr " " "\n" | sort | uniq -d | xargs
Here are the methods:
In a script
dpkg-deb -I <The .deb> | grep -E "Depends|Recommends|Suggests|Pre\-Depends" | tr -d "|," | sed "s/([^)]*)/()/g" | tr -d "()" | tr " " "\n" | grep -Ev "Depends|Recommends|Suggests|Pre\-Depends" | xargs
In a script, but not downloaded (remote)
apt-cache show <The package name> | grep -E "Depends|Recommends|Suggests|Pre\-Depends" | tr -d "|," | sed "s/([^)]*)/()/g" | tr -d "()" | tr " " "\n" | grep -Ev "Depends|Recommends|Suggests|Pre\-Depends" | xargs
Human readable
dpkg-deb -I <The .deb> | grep -E --color=none "Depends|Recommends|Suggests|Pre\-Depends"
Human readable (remote)
apt-cache show <The package name> | grep -E --color=none "Depends|Recommends|Suggests|Pre\-Depends"
Get amount of dependencies
dpkg-deb -I <The .deb> | grep -E "Depends|Recommends|Suggests|Pre\-Depends" | tr -d "|," | sed "s/([^)]*)/()/g" | tr -d "()" | tr " " "\n" | grep -Ev "Depends|Recommends|Suggests|Pre\-Depends" | xargs | tr " " "\n" | wc -l
Get amount of dependencies (remote)
apt-cache show <The package name> | grep -E "Depends|Recommends|Suggests|Pre\-Depends" | tr -d "|," | sed "s/([^)]*)/()/g" | tr -d "()" | tr " " "\n" | grep -Ev "Depends|Recommends|Suggests|Pre\-Depends" | xargs | tr " " "\n" | wc -l
- 61
- 1
- 3
apt-cache depends [Package-Name] will work as well. Although if you source the .deb package from outside your sources list, things like
apt-cache showpkg [Package-Name] && apt-cache depends [Package-Name] might show outdated info or might not sync with the actual installed package hence
dpkg -I [Package-Name] would work best in that case.
- 31
In case you have the uninstalled package (usually downloaded manually from outside a repository), you need to use dpkg. The following command will show a summary of the package informations, including it's dependencies:
dpkg --info [package name]
In case the package is already installed on your machine (originated from the repository or from a manual download), or is not installed but is available in the repository, you can use apt. The following command will show only the list of it's dependencies.
apt depends [package name]
- 1,460
For a specific package version:
apt-cache show <package_name>=<version>
To find available versions: How can I check the available version of a package in the repositories?
- 146
Here is some sloppy, and probably not very encompassing post-processing you can do to dpkg -I output to get dependency items as a list:
Condensed for computers
# dpkg -I package.deb | python -c "import sys, re; t=re.split(r'\n(?= ?[\w]+:)|:', sys.stdin.read()); print '\n'.join([i.strip() for i in {key.strip(): value.strip() for key, value in zip(t[::2], t[1::2])}['Depends'].split(',')])"
Expanded for humans:
import sys, re;
# Split keys and values into pairs (zipped together later)
t=re.split(
sys.stdin.read()
# Newline separate each dependency
print '\n'.join([
# Trim each dependency value
# Build assoc array from package metadata
- 3,372
