What are the requirements for installing VirtualBox from the Ubuntu software center? I tried to download from the center but it says that there is additional software that is missing...
I am a new user.
Fabby
  • 35,017
I rarely install VirtualBox from the Ubuntu Software Center, because it is always outdated. I will show you how to install it manually:
Download the version with your correct architecture:
Save the file in your home folder, then start up the terminal by pressing Ctrl+Alt+T, and then run the following command:
sudo dpkg -i virtualbox-4.3_4.3.28-100309~Ubuntu~raring_*.deb
After that, if it still gives you a missing packages list, try:
sudo apt-get -f install
Last, but not least, you need to install the VirtualBox 4.3.28 Oracle VM VirtualBox Extension Pack, after download, open it with VirtualBox, and you're done.
blade19899
  • 26,994
what about downloading .deb package directly from Oracle and installing it with
sudo dpkg -i packageName.deb
in terminal?
If something is missing, you can anyway try to find missing packages via
Cheers,
Silvia
Silvia
  • 538
