I'm kinda new at Ubuntu/Kubuntu, and I had a few issues. For whatever reason, and at random times Kubuntu locks up and I cannot use either mouse nor keyboard. I have tried jumping to terminal mode, but even that doesn't work. Actually, while I was typing this, it crashed and I had to switch to my Eee Pad. I've searched Google, ran diagnostics, and tried to read system logs, with little luck. I think the problem may lie in my graphics, but I'm willing to do anything to fix it.
If it helps at all, when I ran the diagnostics my PC failed the "graphics/display" category.
If you computer hardware diagnostics is failing on the graphics card as you say it is not related to software, Ubuntu or drivers, your hardware is defect.
Knowing this it is normal that you might have crashes like that: your computer hangs because something really bad happened due to the hardware fault.
You should take your computer to a repair shop or if you can do it yourself and its possible you should replace the defect hardware.
  • If you are using an external graphics you should test it with a different card (same chipset if possible so you dont need to install / remove drivers), reason for that is that it can be just the card but your motherboard can be the cause instead.
  • If you are using an internal graphics card (built-in) you should try to replace the RAM you have (since the card uses shared memory with RAM) and if that did not help your motherboard needs to be replaced.
Bruno Pereira
  • 74,715
