64
I'm new to Ubuntu, so please bear with me. I installed pip using this command: sudo apt-get -y install python-pip. Then I installed NLTK using the command on their website, which was: sudo pip install -U nltk. But then I stumbled on this question that says that everything I did was a "broken practice". The line that struck me the most was that using sudo pip is inherently wrong and that giving pip too much force could damage operating system files. Can anyone validate this claim?
Note - I only used sudo because when I tried the command apt-get -y install python-pip it gave me 2 errors:
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
6 Answers6
89
Both sudo pip install and its other common variant sudo -H pip install should not be encouraged because it is a security risk to use root privileges to use pip to install Python packages from PyPI (Python Package Index).
From https://stackoverflow.com/a/21056000/486919 (emphasis mine):
When you run pip with sudo, you run setup.py with sudo. In other words, you run arbitrary Python code from the Internet as root. If someone puts up a malicious project on PyPI and you install it, you give an attacker root access to your machine. Prior to some recent fixes to pip and PyPI, an attacker could also run a man in the middle attack to inject their code when you download a trustworthy project.
As mentioned at https://security.stackexchange.com/a/79327/8761, it is important to note that anyone can upload Python packages, including malicious ones, to PyPI.
In short, in accordance with the principle of least privilege, don't use sudo with pip to install Python packages from PyPI unless you absolutely need to. Instead, consider using pip install --user (note that pip install with no sudo nor additional flags/options defaults to pip install --user on Ubuntu currently) or virtual environments (such as virtualenv). If you see people recommending sudo pip or sudo -H pip, please tell them not to.
edwinksl
  • 24,109
27
You must use sudo to install pip with apt (sudo apt install python-pip), but as stated in edwinksl's answer you should not use sudo to install packages with pip, you should use pip install --user <package> to install only for your user, or use a virtualenv to even further restrict the scope of the package.
Apt installs packages from Ubuntu's repositories, whereas pip installs user-uploaded packages from PyPi which could be malicious.
10
And for a more tempered reply:
  1. You indeed do always have to sudo apt-get install ..., that's just how the tool was designed to work.
  2. Using sudo [-H] with pip install is both possible & optional, depending on what exactly you want to do (and hence, "controversy").
One of Python's mottos is "There should be one-- and preferably only one --obvious way to do it." And like most mottos, it's broken with sardonic glee seemingly at every possible opportunity. (That's why mottos exist, I guess.) Unfortunately, in my most humble opinion, the Python ecosystem consists of many conflicting "hard & fast" rules, never to be broken...except for when "yada yada yada" (devil, details, etc). In almost all cases, this is due to historical evolution of the language & tools (and who wants/needs a history lesson when they just want to get on with their job) -- but also can be due to differences in Mac/Win/*Nix platforms (e.g., Unix/Linux has a similar mentality, but has the advantage of decades more maturity.) So please do take all these "broken practice" & "inherently wrong" cargo-cultists with a huge pinch of salt. Some actually do mean well. (Others are just, well, mean.)
First of all, rather than basic "per-user installs", you'll almost always prefer a virtualenv, because really, that's probably what you'll end up needing. So you might as well start with it now. How this is done, exactly, "depends" (see Python motto, above). If you're using Conda (mostly for Mac & Windows), it'll be set up using Conda. If using "pure" Python [sic], it depends on which version & what python utils you have, but virtualenvwrapper is pretty handy.
Second, just as a counter-example to the "never sudo" rule, you may prefer to sudo -H pip install -U numpy, which is perfectly fine, even advantageous, in that it can allow one to avoid downloading/reinstalling/maintaining big libraries, where you only want/need one version, into every virtualenv separately. Big, popular frameworks like scikit-learn, NumPy, matplotlib, SciPy, pandas, etc., can be installed once & done and re-used across environments. Further, your local friendly sys-admin might be able to get these installed for every user on a system -- and obviously they'd be doing this via sudo, as well, e.g., for more complicated installations, such as TensorFlow.
And, lastly, if you are installing some random 3rd party library that does such-and-such (Twitter API, text munging, code formatting, etc), then I totally agree -- don't install it as root via sudo. Sure, install it as your current user. But just remember, your user account has all your really important stuff.
wjandrea
  • 14,504
michael
  • 2,109
Using "sudo pip install" can and will overwrite python content provided by your OS vendor. When that happens, any vendor packages affected by this will not pass an "rpm --verify" and your packages will appear to be corrupted.
Do you want to use system-administration tools that your OS vendor has tested, or is it okay to use untested components you downloaded from the internet?
When, not if, a malicious package gets uploaded to PyPI... people who use "sudo pip install" will end up running that malicious payload with full system privileges. Do you want that? (#principleofleastprivilege)
If it's just your laptop, and you're only risking a few cat pictures, then the risk is probably low... but if it's a multi-user system, then the risk is now multiplied by N. If you have data on the system that has value, or system availability or reliability have value, then the risks also go up.
Please feel free to choose your own adventure, but please get the informed consent of the other users that could be affected by your choice. They may not be comfortable with the same level of risk as you.
To add to these answers: I do not know about Ubuntu, but on Fedora I am able to use sudo dnf install python3-numpy format to install MANY packages useful to me. This does not have the disadvantage of being insecure (distro repo maintainer has validated packages), but also allows you to install system-wide. Only drawback is that the distro repo versions may be slightly lagging the packages in PyPI.
Milind R
  • 121
-5
No, this is correct. I cannot validate this claim. I always use sudo -H with pip. pip can only damage operating system files as much as apt. Only do not use sudo with pip when you want to install only for that user.
fosslinux
  • 3,881
