I run pip install pycosat but I get:
Downloading/unpacking pycosat
  Downloading pycosat-0.6.1.tar.gz (59kB): 59kB downloaded
  Running setup.py (path:/tmp/pip_build_masi/pycosat/setup.py) egg_info for package pycosat
Installing collected packages: pycosat
  Running setup.py install for pycosat
    building 'pycosat' extension
    x86_64-linux-gnu-gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -DPYCOSAT_VERSION="0.6.1" -I/usr/include/python2.7 -c pycosat.c -o build/temp.linux-x86_64-2.7/pycosat.o
    pycosat.c:9:20: fatal error: Python.h: No such file or directory
     #include <Python.h>
compilation terminated.
    error: command 'x86_64-linux-gnu-gcc' failed with exit status 1
    Complete output from command /usr/bin/python -c "import setuptools, tokenize;__file__='/tmp/pip_build_masi/pycosat/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-40CYkM-record/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
creating build/lib.linux-x86_64-2.7
copying test_pycosat.py -> build/lib.linux-x86_64-2.7
running build_ext
creating build/temp.linux-x86_64-2.7
 #include <Python.h>
Cleaning up...
Command /usr/bin/python -c "import setuptools, tokenize;__file__='/tmp/pip_build_masi/pycosat/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-40CYkM-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip_build_masi/pycosat
Storing debug log for failure in /home/masi/.pip/pip.log
I run sudo -H pip install pycosat but I get:
Collecting pycosat
  Using cached pycosat-0.6.1.tar.gz
Building wheels for collected packages: pycosat
  Running setup.py bdist_wheel for pycosat ... error
  Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-0CcATa/pycosat/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" bdist_wheel -d /tmp/tmpa1EG1Fpip-wheel- --python-tag cp27:
  running bdist_wheel
  running build
  running build_py
  creating build
  running build_ext
   #include <Python.h>
  Failed building wheel for pycosat
  Running setup.py clean for pycosat
Failed to build pycosat
  Running setup.py install for pycosat ... error
    Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-0CcATa/pycosat/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-l6ZMSb-record/install-record.txt --single-version-externally-managed --compile:
    running install
    running build
    running build_py
    creating build
    running build_ext
     #include <Python.h>
Command "/usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-0CcATa/pycosat/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-l6ZMSb-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-0CcATa/pycosat/
Comments
I do not like to use sudo with pip. But probably necessary here. I do not understand why gcc error there in compilation.
How can you install Pycosat in Ubuntu?
David Foerster
  • 36,890
  • 56
  • 97
  • 151
From https://stackoverflow.com/a/32030746/486919, run sudo apt-get install python-dev before running pip install pycosat.
edwinksl
  • 24,109
2021 update: to solve this you should actually use the command:
sudo apt-get install python3-dev
... unless you are using python2.
