50
How do I assign custom icons to folders, as well as the default folders Desktop, Downloads, Music, etc.? I know that one way is to assign the properties of folders, but I want to assign icons in the same way that are assigned the default folders, so the custom icons will also appear in the Nautilus bookmarks. I've also seen this question >> custom icon in "Places" menu <<, but that is not what I seek.
I want the markers to display custom icons like the dolphin. I know it's possible, because the folder "Desktop", "Documents", "Music" have their own custom icons in bookmarks. How?
Alexis Wilke
  • 2,787
Frank Souza
  • 653
Custom icon selection
In the file manager (nautilus):
  1. right click a folder's icon
  2. click on properties in the contextual menu
  3. in the properties window click on the framed icon (top left)
    • that should open the dialog to choose a new icon
  4. Pick an icon from /usr/share/icons
the default folder icons are in the Humanity sub-folder.
Custom icon backup & restore
The informations seems to be saved by nautilus in ~/.local/share/gvfs-metadata.
Note that the directory contains lots of other data (emblems and more). As far as I know they are in binary format so I wasn't really able to pinpoint what's really needed in a backup. Still file path of the icons shuld remain exactly the same between backup and restore for this to work
Resource: Ubuntu Forum thread
  1. Right click on the folder whose icon you want to change and select "Properties".
  2. In the properties window, click on the image of the icon (The icon which is in the "Basic" tab which is opened first by default). An icon selection window will open.
  3. In the icon selection window, choose the icon or image you want to set for the folder.
toothie
  • 131
Emblems were removed from Nautilus in version 3.0. There is a workaround consisting in using python-nautilus and a project https://github.com/allefant/Nautilus-Emblems-Menu-Extension that adds the Emblems option to the right-click menu.
Follow the instructions here http://www.webupd8.org/2011/12/how-to-manually-add-emblems-in-nautilus.html
alfC
  • 3,584
